20 Most Recent
Amana ARB224RCC Bottom Freezer Refrigerator Questions & Answers
I have a hard time opening and closing the frezer
HI,
Do you have frost in the freezer too? Was the door left open and caused the rails to freeze with ice? Normally this would be the cause of the problem you described. The only fix tis to remove all the frost and ice from the rails to work properly and find the cause of the air leak that created the problem in the first place.
I hope this helps I’m happy to help further over the phone at
https://www.6ya.com/expert/gere_bf68e6055dd61249
I have an Amana BR22VW
Hello, welcome to FixYa.
That is for the automatic defrost timer, the knob is to manuallly advance the timer for servicing purposes.
Hope that answer's your question. Thank you for choosing FixYa. Let us know if we can assist you in any manner in the future.
Please take a moment to rate the assistance you received here today and a brief testimony is always appreciated as well.
Regards,
Macmarkus :)
Fan not working
Probably your fan is burnt. Replace it. It is running on mains supply, so you can take it out & check.
sonsunny
GFreezer is cold, suddenly won't freeze
Hi, make sure the evap coil and the condensor coils are clean. make sure there is no ice build up on the evaporator located in the back of the freezer. It could also be a bad t-stat or low on refrigerant. Call a tech if it still does not work after you clean and make sure that both coils are clean and ice free.
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Need to find water filter on my amana model
Install Water Filtration Cartridge (some
models)
a. Remove bypass cartridge from water filter head in rear
right corner of refrigerator section. Twist cartridge
counterclockwise 1/4 turn and pull down to remove.
Save bypass for use at a later date.
b. See Water Filtration System Installation and
Operating Instructions provided with water filter
cartridge for filter installation and operation.
6/20/2023 3:26:22 PM •
Amana...
Answered
on Jun 20, 2023
Afd2535des not cooling in any department, when I opened the doors, the lights work and the led temp control lights up. I hear a fan start and 5 seconds later the fan stops n leds shut off.
- Check the thermostat: Make sure the thermostat is set to a temperature that is low enough to cool the refrigerator. If the thermostat is not working properly, it may need to be replaced.
- Check the condenser coils: The condenser coils on the back of the refrigerator should be clean and free of dust and debris. If the coils are dirty, the refrigerator will not be able to cool properly. Use a vacuum cleaner or a brush to clean the coils.
- Check the fan motor: If the fan motor is not running, the refrigerator will not be able to cool properly. Check if the fan motor is receiving power and if it's spinning freely. If the fan motor is faulty, it will need to be replaced.
- Check the start relay: The start relay helps the compressor start up. If the start relay is faulty, the compressor may not start and the refrigerator will not be able to cool properly. If the start relay is faulty, it will need to be replaced.
- Check the compressor: If the compressor is not working, the refrigerator will not be able to cool properly. Check if the compressor is receiving power and if it's running. If the compressor is faulty, it will need to be replaced.
2/16/2023 2:42:10 AM •
Amana...
Answered
on Feb 16, 2023
No power to Amana ice and water dispenser. Rest of refer runs fine.
It's possible that the issue could be with a micro switch located on the ice maker cabinet that is activated when the prong on the back of the ice/auger tray is inserted. It's also possible that there could be another issue with the dispenser, such as a problem with the wiring or a malfunctioning component. I would recommend checking the wiring and testing any other micro switches or components that are related to the dispenser to see if they are functioning properly. If you are unsure how to do this, I would recommend consulting the user manual or contacting a qualified technician for further assistance.
1/14/2023 10:27:43 AM •
Amana...
Answered
on Jan 14, 2023
