20 Most Recent Amana 21.9 cu. ft. Bottom Freezer Refrigerator, Easy Fill Internal Water Dispenser Questions & Answers
there is a micro switch behind the door lever wich activates a water valve solenoid that allows water to go thru.
Amana 21.9 cu.... | Answered on Oct 24, 2013
possibly need to clean out vents/drains.make sure door seals all round.no air gaps. blocked vents/air leaks will cause fridges/freezers to work overtime..
Amana 21.9 cu.... | Answered on Feb 17, 2010
Theres a few solutions that could fix this. 1st I would let the unit thaw out could have ice built up on the air passage that wont allow the air to travel freely. Some caused by not having a good seal around the door.
Amana... | Answered on Jun 15, 2019
Always fault find and repair the fault before replacing a board. Without sight of the machine, I can only guess at the compressor.
Amana... | Answered on Jun 08, 2019
go buy a new one
Amana... | Answered on Mar 20, 2019
Make sure that the passage between the freezer and fridge is not blocked
Amana... | Answered on Mar 03, 2019
There should a on-off rocker switch on the icemaker. Turn it off.
Amana... | Answered on Feb 02, 2019
Old model refrigerator have their defrost timer located at the back right upper corner or the left lower corner with a hole slot for a screw driver. New models have it inside the refrigerator near the thermostat control. It also has a hole slot for a screw driver.
Amana... | Answered on Jan 05, 2019
Motor could be burning out and drawing too much power. If it's old not worth repairing.
Amana... | Answered on Dec 29, 2018
Amana 21.9 cu. ft. Bottom Freezer Refrigerator, Easy Fill Internal Water Dispenser Logo
3 questions posted
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
easy fill water dispenser work
  • Refrigerators
