I have an Amana abb1921dew refrigerator that is about 4 years old. Last night it stopped blowing...
(More)
I have an Amana abb1921dew refrigerator that is about 4 years old. Last night it stopped blowing cold air. There is air circulating in the freezer and refrigerator it's just not cold.
We had this problem before, turning down fridge to 4 helped for awhile but now fridge is warm again....
(More)
We had this problem before, turning down fridge to 4 helped for awhile but now fridge is warm again. Freezer is OK. I saw one solution say check/replace evaporator fan motor. There is no air coming out of the slots in the rear bottom of the fridge compartment. The copper coil is clean and the vent in the back is clear of lint.
kstfas, you had helped me in 9/07 about a defrost timer on our refrig. Is this something I can...
(More)
kstfas, you had helped me in 9/07 about a defrost timer on our refrig. Is this something I can replace myself, and if so, what does it look like? I am having the same problems as before....the blower hole is getting clogged up with ice crystals and the cool air can't get to the refrig. I have the lower back panels removed, but not sure what I'm looking for? Any help would be appreciated. thanks...Jason
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
