20 Most Recent
Dell (04U621) for Latitude D600, Inspiron 600M Motherboard Questions & Answers
Plz help me with password
reset cmos IC. remove CMOS battery, leave it for 20 min , put it back on. go to setup and reconfigure.
I cannot format my dell
you have to format your hard drive using a third party disc to erase
everything on your hard drive
During the boot process you will see on the screen to press a certain key
to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll
to advanced bios features press enter change your first boot device to cd,press
escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an
operating system disk to load it onto you hard drive or create a partition to
load another operating system
note after you have loaded the operating system you must go back and change
the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB
drive
right click then select format
another way is to control panel
administrive tools,computer management disk management right click on your
drive select format
hope this helps
Error formating dell
what is the exact error? you may want to make sure no password is set for it in the BIOS and try to boot to the Windows CD and run the format option throught it or the recovery console
How can remove the admin
f you can already login to this computer and you have administrator's rights,
then you do not need the administrator's password. You can go to the Control
Panel - User Accounts to set up other Users or change the password on the
various Users as well as the administrator.
If you need the administrator's
password to set up a new user then there is a way to remove the administrator
password.
You need to download Hiren's utilities and make a boot CD with this
utility. You most likely need to do this from another computer.
For details
on how to remove the administrator password please click on this link :-
http://www.fixya.com/support/r4335021-remove_xp_vista_password
I can't find the CMOS
During the boot process you will see on the screen to press a certain key to enter setup
after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS
hope this helps
I have a Dell 6000m laptop and the message says
Clearing the CMOS (BIOS setting storage) will clear the password.
Go to the Dell website and look for directions on how to clear the CMOS,
or just removing the button cell batter for a few minutes, with the computer unplugged, should also clear it.
Will Not charge with brand new a/ power cord it
The problem is with the AC adapter itself and is a very common problem with Dell AC adapters. My suggestion would be to get an aftermarket AC adapter that can be purchased on eBay as the Dell adapter is around 100.00. You can pick up an aftermarket one on eBay for around 20.00. The problem is a resistor inside the AC adapter that senses when a Dell branded adapter is inserted. What happens is that the resistor will get damaged and since it doesn't recognize the charger as a Dell branded one anymore it won't charge. However it will still run the laptop as long as it's connected. A lot of aftermarket AC adapters bypass this function and work perfectly fine.
Dell 600m laptop fell off table. Pwr connector
Hello there...
As far as I know there is no power fuse on the motherboard.
But can you try this: Power on the laptop without the battery equipped, only use the AC power adaptor.
Hope this helps....:D
Power Jack Repair Advice Needed
The repair really isn't too complicated most times. hardest part is usually removing the old one. I haven't looked up that specific model, they all are different but all the same. Some are placed on a separate small board. some are soldered to the main board. If your considering purchasing replacement board anyways, I would try and fix it and then if that doesn't work exercise your other options.
Thank you,
Lee
I replaced a motherboard for my Dell inspiron 600m
If everything works OK I wouldn't be concerned what the system thinks it is. If you go messing with the bios, and install the wrong version, the your system won't work at all! As long as the system does what it is supposed to do I would care less what it shows as a system name, and wouldn't worry about it.
Hank.
Excellent connection wireless but not connected to internet
goto start icon in your toolbar.
goto run
type: cmd (press enter)
(a black box will come up)
type:
ipconfig /release (press enter)
ipconfig /renew (press enter)
if this does not work, goto start, control panel, view classic settings, click network, you should see you network connect as an icon here, right click the mouse over the icon, select repair. the computer will do a variety of things.
sometimes hotels have a login page that you have to log in through as a guest with your room number to get them working. or, the router might be set to MAC filtering, in which case you need to give the admin you MAC address so you can get on the network.
double check that you are actually getting on the right network. sometimes people set up dummy networks to capture all your data.
