20 Most Recent
Beam Industries 875 Classic Central System Vacuum Questions & Answers
My beater bar is struggling to turn. actually, it
Replace the belt, they should be replaced every 6 to 12 months. A belt may look ok but may have lost elasticity and be stretched out. If your belt is a year or two old it may be an inch or so longer than when it was installed. A stretched out belt may turn the brushroll fine but when it is lowered onto the carpet the belt may slip rather than spinning as fast as needed to properly agitate the carpet fibers.
If the motor isn't spinning properly that could be another problem.
The Vaccum is not turning
you can test this out by taking a small metal spoon and with the bottom side of the spoon insert it into the vac outlet on the wall. you want to touch the two metal pins inside the vac outlet to test if the unit is the problem or the hose is the problem.
If the unit starts, the hose should have a 3 year warranty on it. I recommend you have your nearest beam dealer check it out.
If the unit does not start, it has a 7 or 10 year warranty, the circuitry should be replaced. Again have your nearest beam dealer check it out.
good luck
The electric powerhead for my
The brush roller itself may be warped, or the bearings may be starting to wear out.
Replacing the brush roller may solve the entire problem.
Good luck.
Mark
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
