20 Most Recent ASUS A7N8X-E Deluxe Motherboard Questions & Answers
your board should do that auto. do you know how to use cmos it is the only way to do that
ASUS A7N8X-E... | Answered on Oct 26, 2013
It is embedded on motherboard. Download driver.Unzip. Run setup in marvell_v627\Marvell\Win2K_XP after extraction.
Asus A7N8X-E Deluxe Marvell LAN Driver 6.27
ASUS A7N8X-E... | Answered on Oct 21, 2012
Temporarily swapping-in another power-supply is the first thing to try.
Don't connect the disk-drives, CD/DVD drive, nor 3.5-inch drive.
If the computer "beeps", and shows the POST (Power On Self Test) screen, then changing the power-supply is the solution.
Look at the motherboard -- any "blown" or "bulging" capacitors?
ASUS A7N8X-E... | Answered on Oct 27, 2009
Do you have a LAN connection on the machine that you use? That would be an area to start to make sure that (when a LAN cable is plugged in, the incoming and outgoing lights will blink) the power supply still works. If the power supply does still work, it could be the motherboard or CPU which isn't working. It could be something simple like thermal compound needs to be reaplied to the CPU, or there may be faulty hardware. Let me know if the power supply is still working.
ASUS A7N8X-E... | Answered on Apr 15, 2009
its falt of internal battery
ASUS A7N8X-E... | Answered on Apr 06, 2009
Visit this website:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3184154&lc=en&dlc=en&cc=us&lang=en
Once the page loads, select the Operating System currently installed on your computer. Once you select it, scroll down the page until you find the section labeled, "Original Drivers." Inside that section, locate and click on the link for, "Summer 2006 Original Realtek High Definition Audio Drivers." Now you will be taken to a page where you can download the drivers for your sound device.
Once you downloaded the driver, open it. An installation utility should open and begin the driver installation process. Once the installation is complete and you restarted your computer, you should have sound abilities again.
Let me know if I can assist you further, or if I need to explain any of my instructions with more detail. (If this solves your problem, please assist me by rating my solution.)
ASUS A7N8X-E... | Answered on Mar 22, 2009
When your pc starts to boot up do you get two beeps one then another, although not two together, if not and only one beep occurs this could mean a memory problem, two beeps together normally a cmos bios problem.(Only part you've not changed was your ram) Do you get as far as the bios screen?, if so look for a line in advanced cmos settings, saying 'halt on all errors' dissable this and sometimes on boot up the problem will show itself in the initial dos screen. Keep diggin.
ASUS A7N8X-E... | Answered on Mar 01, 2009
looking for a guide to buy the best motherboard ,check this website http://www.itreviews.co.uk/guide/hguide11.htm
even this website http://compreviews.about.com/od/buyers/bb/DesktopPCs.htm
you will get an idea,,,,,,,
ASUS A7N8X-E... | Answered on Jan 12, 2009
intel desktop dg31pr &grafic card  sparkle
it cannot find COMMAND.COM
Explanation: When you boot up DOS, you are placed at what is commonly called the "C: prompt", where you can type commands or run programs. The part of DOS that reads what you type and executes commands is called the command interpreter, which is stored in the file "COMMAND.COM". This interpreter is loaded when you start the system or when you start an MS-DOS session under Windows 95, and is also reloaded in some cases when you finish running a program. In this case, the system was unable to find COMMAND.COM and therefore halted the system.
try this
  • Make sure that COMMAND.COM is in the C:\ root directory, or if it somewhere else, that there is a line in AUTOEXEC.BAT that reads "COMSPEC=X:\PATH" where "X:\PATH" is wherever COMMAND.COM resides.
  • Edit the PATH command in your AUTOEXEC.BAT file, if you are trying to run a command in another directory that should be accessible from anywhere.
please send me a feed back if this works out thnk you.
ASUS A7N8X-E... | Answered on Dec 13, 2008
You can find any drivers you need here:
http://support.asus.com/download/download.aspx?modelname=A7N8X&SLanguage=en-us
Just select your operating system from the option on the page (XP, Vista, etc).
Cheers
Nick
ASUS A7N8X-E... | Answered on Dec 12, 2008
Hi omega_1_80, two things come to mind. I gather you used the data cable from the MSI system when you switched to it. Try connecting a new data cable (80-pin) in your system. Set the bios to Auto for the PATA 160 drive. If the drive still seems funny turn off S.M.A.R.T. See if these suggestions help.
Good luck omega_1_80!
Mike
ASUS A7N8X-E... | Answered on Nov 30, 2008
Need to closed application properly. Go to the task manager (right click on task bar and select task manager) and check in application task if there is any program running also check Process tab and ed task the application related to webcam. Hope this will fix the webcam issue.
ASUS Computers &... | Answered 15 hours ago
You need to be more specific.
There is nothing in your request as to what you want with the registration key.
Do you want to share it?
Do you need one?
Please elaborate.
ASUS Computers &... | Answered on May 15, 2019
I think you mean cd/dvd drive, not the "disk drive" which is the main storage device inside the computer and is only accessible by taking the computer apart. On my Asus, the button that opens the cd/dvd tray is on the tray, which is on the right side of the computer. If you can't find it or it doesn't work, you can open the tray by choosing "eject" on the file menu or "home" menu, or whatever shows the cd/dvd drive on your operating system (probably windows).
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Download the latest driver from Asus.
ASUS
ASUS Computers &... | Answered on May 13, 2019
when you try to use regular DVD or blu ray players for GAMES , what do you expect . MIRACLES
ASUS A7N8X-E Deluxe Motherboard Logo
14 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
motherboard not
  • Computers & Internet
