FixYa.com
ASUS P5N32-SLI Deluxe  Motherboard
All Products > ASUS > Motherboards
Problems with ASUS P5N32-SLI Deluxe Motherboard?
Search inside ASUS P5N32-SLI Deluxe Motherboard Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS P5N32-SLI Deluxe  Motherboard RSS Feed Post a New Problem
New Installation P5N32-E SLI
spec Processor E6600 2.4 mobo P5N32-E SLI GC XFX 8800GTS 640mg Ram patriot PDC22G6400LLK 2 X 1GB HDD WD 80gb...
1 Solution
help wanted.. really weird..
help! when i plug the power cord to the power supply, the cpu automatically run itself, but the screen is just blank...
1 Solution
hard drive recognized as slave drive
i have a fic va 503+ motherboard the primary hard drive is a western digital 60 gb its recognized as a slave drive even...
1 Solution
Serial port connector for Asus Motherboard
On an Asus motherboard I am considering, there is a 10 pin connector to which you can attach a 9 pin RS-232 port that...
1 Solution
No boot...no nothing...I am screwed
I am having a huge problem... I took the heatsink off of my CPU in order to replace it and while it was off, I was on...
1 Solution
my dell pentium 2 with windows XP...
hi guys my dell computer with a windows XP professional keeps on re-stating it self and it does so even when am at the...
1 Solution
ethernet adapter problem
9 months ago I bought the asus motherboard and 3 things don't work... .1. the Ethernet adapter dosn't work (the...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorATX
CompatibilityPC
ChipsetNVIDIA nForce4 SLI
Compatible ProcessorsIntel Celeron, Intel Pentium 4, Intel Pentium D
Front Side Bus Speed1066 MHz
Technical Features
Expansion SlotsPCI x 2 · PCI Express x1 x 2 · PCI Express x16 x 2 · PCI Express x4 x 1
Integrated Input/Output PortsSerial Port x 1 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · FireWire (IEEE1394a) x 2 · Game/MIDI Connector x 1 · Floppy Port x 1 · RJ45 Lan Port x 2 · USB 2.0 x 10
Storage Controller Type(s)DMA/ATA-133 (Ultra) x 2, Serial ATA II x 4
RAID SupportRAID 5 · SATA RAID 0 · SATA RAID 1 · SATA RAID 0+1 · JBOD Support
Processor
Max supported CPUs qty1
Socket TypeSocket LGA775
Memory
Max Supported RAM16 GB
Memory TypeDDR2 SDRAM
Supported RAM Speeds533 MHz · 667 MHz
Number of Memory Slots4 x 240 Pin DIMMs
Audio / Video
Audio OutputSound Card · Line Out · SPDIF out · 7.1 Channels · Coaxial Out · Optical Out
Video InterfaceDual PCI Express x16
Audio InputMicrophone Jack · 1 x Line In
Integrated AudioRealtec ALC850
Communication
Networking TypeDual Network adapters, Ethernet, Gigabit Ethernet, Fast Ethernet
Other Features
Package Qty1
Chassis TypeDesktop
Other FeaturesHyper Thread Technology Ready · Dual Channel Memory Architecture · Chassis intrusion detection · 64bit Ready · Dual Graphic Cards
Fans1 x 4-pin fan headers · 5 x 3-pin fan headers
Dimensions
Depth9.6 in.
Width12 in.
Warranty
Warranty3 Years
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
