20 Most Recent ASUS P5RD2-VM Motherboard Questions & Answers
We need to know what OS is installed and all hardware that you have added to it.
ASUS P5RD2-VM... | Answered on Dec 31, 2017
If this is happening only by using of Integrated (Radeon X300) graphics,than chipset is overheating.
Solution:Chipset cooling fan : )
ASUS P5RD2-VM... | Answered on Jan 10, 2014
WHAT ARE THE PROBLEM ?.
ASUS P5RD2-VM... | Answered on Oct 11, 2013
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
ASUS P5RD2-VM... | Answered on Mar 16, 2013
Hi, you can download a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5RD2-VM&p=1&s=22
Please select your operating system.
Select manual and click on global.
Unzip the file before you can read it.
Upgrade the other drivers if some missing.
Run also windows update.
You may have to disable the onboard graphic in the bios.
You can also try to upgrade the bios by using the
asus upgrade utility.
The graphic card must be a PCI-E socket.
I guess the old driver is making a conflict as it is the same brand.
And download the latest driver for your graphic card here:
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.48&lang=us&rev=&ostype=Windows XP - Professional/Home
ASUS P5RD2-VM... | Answered on Sep 09, 2011
Apparently yes. To determine that for sure boot in Safe Mode and run it there - the drivers will not be loaded so if it stops you will know it's a hardware problem.
ASUS P5RD2-VM... | Answered on Aug 25, 2011
i dont if you mean your graphics card or you cant see it this might be a driver issue
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers if you don
ASUS P5RD2-VM... | Answered on Aug 24, 2011
Here is an official link for you to download the audio drivers that are missing from your motherboard. Just choose your operating system (windows xp, vista etc) and download the drivers.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
ASUS P5RD2-VM... | Answered on Aug 06, 2011
Yes you can install the 1Tb SATA hard drive on this motherboard.
ASUS P5RD2-VM... | Answered on Jul 16, 2011
the RAM you have ut into your computer is faulty and causing the system to do a beeping noise by removing the ram stick you have put in will stop the beeping sound, Depending on how many ram sticks you have put in your computer it could be just a single faulty ram stick try removing them one by one and rebooting your system as it could be just the one, if after removing them one by one the sound still happens you will have to buy a new stick of ram to get your computer up and running, Let me know the outcome of this using the comment box , Kronoguy
ASUS P5RD2-VM... | Answered on Jun 29, 2011
Dear raivo_bludja ,
please download your ASUS P5RD2-VM drivers from here and install
http://in.asus.com/Motherboards/Intel_Socket_775/P5RD2VM/#download
Thanks for your posting
ASUS P5RD2-VM... | Answered on Jun 24, 2011
are you running it in dual channel?
ASUS P5RD2-VM... | Answered on May 12, 2011
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as:
- System BIOS (including motherboard, add-on cards, etc..)
- Motherboards resources
- Memory mapped I/O
- configuration for AGP/PCI-Ex/PCI
- Other memory allocations for PCI devices
Different onboard devices and different add-on cards (devices) will result of different total memory size.
e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses.
On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices.
This limitation applies to most chipsets & Microsoft Windows 32-bit version operating systems.
If you install Windows 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. Chipsets later than Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture support memory swap function. 2. Windows 64-bit OS which can address more than 4GB memory. You can check below URLs for reference:
http://dlsvr.asus.com/pub/ASUS/mb/4GB_Rev1.pdf
hope this helps
ASUS P5RD2-VM... | Answered on Apr 18, 2011
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select drivers that matchesyour Windows operating system. Please click on this link to their WEB supportsite : - http://support.asus.com/download/download.aspx?SLanguage=en-us
ASUS P5RD2-VM... | Answered on Apr 14, 2011
ASUS P5RD2-VM Motherboard Logo
68 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
motherboard p5rd2 vm 400watt psu 1gb
  • Computers & Internet
