20 Most Recent Bissell 7950 ProHeat Upright Wet/Dry Vacuum Questions & Answers
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
BISSELL 9500 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Bissell 7950... | Answered on Oct 15, 2017
Contact Consumer Care for this 1-800-237-7691
Bissell 7950... | Answered on Jan 30, 2016
I've got the manual for a BB 8910, they are available on the net if you look hard. It sounds like the mix switch has become dislocated from the regulator. If it's similar to mine, you should be able to remove the cowlling from the base unit when in the tank access position.
Bissell 7950... | Answered on Jan 13, 2016
Hi Jeremy! You may want to have one of our techs at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Bissell 7950... | Answered on Apr 25, 2013
Your extraction pump is bad. it needs replaced by a Repair center such as Sears.
Bissell 7950... | Answered on Apr 18, 2012
there could be a couple of things wrong with this...
first, make sure that the hose/floor selector is set to the floor setting.
second, make sure that the rubber seal is there on the unit between where your clean/dirty water tank meet the main body. if it is not there, you will have no suction in the unit.
third, make sure that the lint trap on your suction port is clean. It should be a little red screen on the dirty water tank.
4th, if someone has taken the clear window off at the front to clean recently, make sure that it is back in its original position. off just a little will affect the suction a lot.
Good luck and hope this helps.
Bissell 7950... | Answered on Nov 05, 2010
Hi
Please follow this procedure to resolve the issue---
1. Test the trigger mechanism. There should be 1/4" of free travel before 1/4" of resistance.
If not, ensure that valve is seated correctly. If valve is OK, replace the trigger rod.
2. Check resistance of the SmartMix knob by turning it from left to right several times. If
difficult to turn, check to see that the piston is installed correctly (with housing removed)
3. Check seals on Clear Water Tank and Solution Tank. If necessary, re-seat or replace
seals.
4. Check valve action on Clear Water Tank and Solution Tank by depressing them with
your finger. The valve should move up and down. Replace if necessary.
5. Check position and condition of gaskets at nozzle window top and motor duct. Re-seat or
replace if necessary.
6. Check position of tabs (2) at upper rear of nozzle window to ensure they are inserted
properly into their alignment holes. Re-seat if necessary.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Bissell 7950... | Answered on Oct 14, 2010
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Bissell 7950... | Answered on Sep 22, 2010
Bissell 7950 ProHeat Upright Wet/Dry Vacuum Logo
41 questions posted
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Bissell Vacuums
  • Bissell Vacuums
Most Popular Question
brush off change belt
  • Vacuums
