FixYa.com
Ultra Linear UL-1500XS Car Audio Amplifier
All Products > Ultra Linear > Car Amplifiers
Problems with Ultra Linear UL-1500XS Car Audio Amplifier?
Search inside Ultra Linear UL-1500XS Car Audio... Knowledgebase
Troubleshooting and Support
Solved Problems for Ultra Linear UL-1500XS Car Audio Amplifier RSS Feed Post a New Problem
My Amplifiers is getting warm, is it OK?
1 Solution
Can I hook up an amplifier to my factory...
Can I hook up an amplifier to my factory radio?
1 Solution
american legacy II LA690 amp
i want to know if there is any way you can bypass the overhaul (green light:power, red light:overhaul) because when ever...
1 Solution
Blown Amp
Whilst wiring my stereo in i touched the earth and live onto the live and blew part of the gold leaf connection inside....
1 Solution
jerky rca input/beeping from ground...
had this amp 3 years now and over the last 2 weeks it started making a beeping noise from the ground connection...i...
1 Solution
what ohm load is best?
is the lowest ohm wire configuration gonna get the best sound out of your amp? ive got a 1 ohm stable amp, is that what...
1 Solution
Amp installation?
I have a 2 channel, 2 ohm stable amp, and 2 4 ohm subs. I have each sub wired positive to positive, and negative to...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeMono Channel
Bass BoostWith Bass Boost
BridgableNot Bridgable
Power Output
RMS Power at 4 Ohms750 W x 1
RMS Power at 2 Ohms1000 W x 1
Performance
Frequency Response10 Hz - 350 Hz
Dimensions
Depth17 in.
Height2.75 in.
Width13 in.
Other Features
3 Way ReadyNo
Input Voltage12 volt
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
