20 Most Recent Cnet CWR-854 Router Questions & Answers
ping it first. got to start menu, run, type cmd, press enter, and type, ping 192.168.1.254. you should get a reply after you did that. if not, connect to the access point first and go to wireless connection status, click properties, scroll down and look for the internet protocol (TCP/IP) and highlight it and click properties, mark the use the following ip address and type 192.168.0.1~100. this means choose a number from 1 to 100 onthe last slot. after that press tab on your keyboard and you will see that it will automatically generate the default subnet mask. press ok and close the application. got to start menu, run type cmd press enter and type ping 192.168.1.254. if it does not work, i do not know what else you can do. just remember, if it work or not, be sure to put the setting of your wireless network connection status and mark obtain IP address automatically. press ok and close application.
Cnet CWR-854... | Answered on Mar 23, 2015
No problem at all. The router can function as bridge with no conflicts with other routers.
Cnet CWR-854... | Answered on Jan 31, 2015
The router should be configured with your IP address.
Gopakumar Gopalan Google
Cnet CWR-854... | Answered on May 18, 2014
why would you want to do that? ;O)
need more information
If you are trying to set up the router for the first time ensure you are using a cable not wireless connection. With wire connected can you get the set up screen on that ip? if not open a dos window (start>all program>accessories>command prompt) and type ipconfig and it will tell you the ip the router is using. try using that ip instead
Cnet CWR-854... | Answered on Apr 04, 2014
See Page 11 for user name and password
http://www.cnet.com.tw/support/manuals/cwr-854(f).pdf
Cnet CWR-854... | Answered on Dec 25, 2013
uh, that sounds like a self assigned IP. are sure your device has a connection to the internet?.... well i suppose it must if your on fixya.... uh, i think WPS is way to connect to a router without using the password.
You better just have a professional make a house call, I think you maybe your in over your head. Way too deep for message board help.
Cnet CWR-854... | Answered on Nov 21, 2013
I have that router... I HATE IT!!!
What I did was... #1. Unplug both the router and modem for about a minute. #2. Plug them in again and when they are both fully booted up... #3. Press and hold in the WPS button on the back or the router for approximately 5 seconds. #4. You should see a wireless network become available called MyWLAN #5. Just go through the router setup.
Hope this helps a little
Cnet CWR-854... | Answered on Jul 02, 2013
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Cnet CWR-854... | Answered on Nov 03, 2012
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
Cnet CWR-854... | Answered on Jul 19, 2011
These aren't widely used in the United States, however it appears that there should be a small reset button on the back of the device. There may be a graphic of an arrow going into a circle above or near it. Press and HOLD that button for 15-20 seconds and then release. All of the lights will go on the router and then go off.
IMPORTANT: When you do this, all of the settings in the router will be cleared and it will go back to factory settings. The default username and password at that point are admin and admin.
You can then go to http://www.cnet.com.tw/html/Services.html to obtain an owners manual for the device and step you through setting it back up.
Hope this helps!
Cnet CWR-854... | Answered on Jun 20, 2011
You should perform a Hard Reset to restore the router to its factory settings. This will automatically reset the password to the default listed in the manual. From there, you can easily change the password (and the user name) in the router settings to whatever you see fit. 1. With the router plugged in, used a pen or similar object to depress the router's recessed reset button. Hold it for 30 seconds, then, while continuing to hold the button down, unplug the router. 2. Hold for 30 more seconds with the router unplugged. 3. While continuing to depress the button, plug the router back in and continue depressing the button for a final 30 seconds. Your router should now be restored to factory settings.
Cnet CWR-854... | Answered on Mar 05, 2011
Cnet CWR-854 Router Logo
79 questions posted
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Jim LeVerso - IT...
Jim LeVerso - IT...
Pamela Bates
Pamela Bates
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cnet Computers & Internet
Most Popular Question
cnet wireless router model cwr 854v
  • Computers & Internet
