20 Most Recent
Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard Drive Questions & Answers
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
12/15/2010 4:52:27 AM •
Fujitsu...
Answered
on Dec 15, 2010
How much is the cost mhv2040ah 40 gb hard drive
Hi
This Neo , it would cost you $40 in Ebay .
or
ALLHDD.com the number 718-766-5269 .
the cost is $54 . Check it .
or
Check it in amazon there is 8 stores where you can get it.
11/2/2010 12:54:46 AM •
Fujitsu...
Answered
on Nov 02, 2010
My 10 gb fujitsu hard disc is not detected by ide
Hello, If this is an external drive and your using Windows plug the drive in and open Control Panel, then open administrative tools,next, open computer management then on the left side under storage open disk management. Your drives should show up here identified as letters, C: - D; etc. If your new drive shows up here click it or right click it to see if it needs to be initialized,if it does do so. Go back to My Computer and see if it shows up there.
12/12/2009 3:48:44 AM •
Fujitsu...
Answered
on Dec 12, 2009
I dropped my laptop, recovered the hard drive and
The HDD is damaged.
No, it is not possible to transfer the disc to another HD case. First, HDDs are assembled in clean rooms because minute specs of dust can ruin the disc; Second, the disc has addresses on it that correspond to the firmware on the drive
11/6/2009 1:25:37 AM •
Fujitsu...
Answered
on Nov 06, 2009
