20 Most Recent Troy-Bilt 24A-06MM066 - CSV060 24" 173cc Chipper Shredder Vacuum Questions & Answers
Your carb is gunky up from bad gas most likely.
Anytime an engine will run for a bit after putting gas into the carb, you are pretty well assured that it's the carb.
Remove and clean the carb paying special attention that all the little orifices are open by spraying carb cleaner into them.
Troy-Bilt... | Answered on Dec 07, 2017
go to MTD site troy-built is owned by MTD
Troy-Bilt Heavy... | Answered on Dec 21, 2017
Best Manuals All diagrams, service/repair instructions, everything from A to Z herein guaranteed best
Troy-Bilt Heavy... | Answered on Nov 09, 2017
you are clearly burning oil. did you overfill? or tilt the unit so that engine oil went into the carb through the breather? now the carb may be soiled/partly clogged, you need to clean it. esp. the idler air part may be at fault. sometimes it is possible to run it at high rev until the fuel has washed out the oil, but better clean the carb and replace the air filter.
Troy-Bilt Heavy... | Answered on Jul 10, 2017
You can prime the engine by taking cover off the air filter and removing the air filter. Cover attached by one screw. Spray starter fluid behind the white-plastic guard. Before attempting to start you must put back filter and cover. If not, the air/fuel mix will not be correct and the engine will quickly die out.
Troy-Bilt Heavy... | Answered on Nov 11, 2016
check the back of pulley there might be 4 holes they will possibly be pusher holes to loosen the pulley from the shaft .
Troy-Bilt Heavy... | Answered on Sep 05, 2016
it is how much power the motor has. In the old days people travelled on horses . One horse produced one horse power. So if you had a buggy with 5 horses attached to it you had a five horse power buggy. So your schredder engine has the equivalent power produced by five horses.
https://en.wikipedia.org/wiki/Horsepower
Troy-Bilt Heavy... | Answered on Jun 29, 2015
Sounds like you put too much sta-bil in it.drain the tank put fresh gas in it.take the carb off and clean it out and should run ok.
Troy-Bilt Heavy... | Answered on Mar 01, 2015
have to go through the motor maker to get those .
Troy-Bilt Heavy... | Answered on Feb 24, 2015
drive both screws all the way in gently clockwise until just snug; then back out both screws counterclockwise one and one half turns the engine should start then adjust for smooth operation and easy starting
Troy-Bilt Heavy... | Answered on May 07, 2014
If your getting spark no doubt its a fuel problem. Does the inside of the cylinder look wet when you removed the plug. The seals in carb go bad all the time. You need a rebuild kit most likely. Very cheap an easy to do. If its a bowl carb it should be done. Should solve your problem. Starting problems are no spark or no fuel. Carb leak an seal get weaker all the time. Gas the way its made today eats the seals away.
Troy-Bilt Heavy... | Answered on Mar 30, 2014
if you are using fuel that has alcohol in it, that can cause the float to sink and all the seals to become brittle.
Troy-Bilt Heavy... | Answered on Feb 23, 2014
replace your ignition module
Troy-Bilt Heavy... | Answered on Sep 30, 2013
Troy-Bilt 24A-06MM066 - CSV060 24" 173cc Chipper Shredder Vacuum Logo
2 questions posted
Top Troy-Bilt Heavy Machinery Experts
quennie732
Mike
lnbn1975
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
View Most Popular
  • Troy-Bilt Heavy Machinery
Most Popular Question
troy bilt 24a 06mm066 csv060 shredder
  • Heavy Machinery
