20 Most Recent
Visonik V2508 2-Channel Amplifier Questions & Answers
Will it go into protect
protect mode is normally when there is to much power running to the amp. if a fuse is blown it normally wont turn on. but take your fuses out hold them to a light and you will be able to see through the fuse. there will be two prongs that will be connected by a U shaped piece of metal. if that piece of metal is still in tacked the fuse is good. you should have a big fuse running with your major power. also check your ground if your ground is loose or has a bad connection. and make sure the the subs go to the amp. if the subs are drawing to much power from you amp it will go on safe mode as in if you have a 2 ohm amp and a 4 ohm speaker. i hope this helps you.
SabiousOne
I have a visonik V8EQ,
I tried my best but was not able to find one also. I was able to browse their website and its not there on the downloads page.
Your best bet would be to contact them at
[email protected]. The shop where you bought the device should give you the manual. How will you install it if you don't have a guide.
Best of luck!
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
I have a Fisher 5
The E display indicates disc loading error.Due to inactivity the carousel loading trays rubber belt would have either become stiff or loose ( depending on which part of the world you live in ).So your loading action is not being completed due to your loose loading belt condition.
There are sensors ( small leaf switches ) which tell the micro controller if the tray has gone in completely and lifted the CD off the carousel tray, only after that the CD starts spinning for play operation. If this sequence does not complete the tray opens and closes by itself in some makes and model during power On
If you are up to it you can open the top cover and see the loading tray and beneath it is the loading belt.Your challenge is getting a replacement today of an old model.
No sound sanyo preamp a8
Is this a new rig or did it just stop working?
If you would elaborate a bit on what you're doing and how it's connected we might be able to solve your problem with high level information.
A list of equipment, including the amplifier you're using, would help.
In general...
If there is a Pre Amp Out stero pair that would go the Amplifier's Pre or Main IN pair.
If there's is a Tape Monitor control, turn it off.
Phono can go ONLY to phono.
Other stereo devices can go to just about anything avalable such as Tuner, Aux, CD, DVD.
