FixYa.com
Danby DDR401 Dehumidifier
All Products > Danby > Dehumidifiers
Problems with Danby DDR401 Dehumidifier?
Troubleshooting and Support
Solved Problems for Danby DDR401 Dehumidifier RSS Feed Post a New Problem
What is the size of the drain connector on...
What is the size of the drain connector on a Danby DDR401 not a garden hose connector, that doesn't fit? THX Mike
1 Solution
Compressor
How do I check if compessor is working properly?
1 Solution
Danby DDR401
This unit does not extract any water. It is approximately 5 years old. It runs find and you can set everything it just...
1 Solution
water full alarm
the water full alarm won't stop beeping although it is emptied very annoying
1 Solution
drain hose not working
After working for about 1 year, the drain hose has suddenly stopped working. It is now insisting on filling the...
1 Solution
20% humidity reading
Is my humidity sensor circuit board toast? after cleaning my dehumidifier, and letting it dry. i plugged it in and it...
1 Solution
DeLonghi 50 Pint dehumidifier DE 500P...
A few days ago my pump on the dehumidifier stopped working...and filled the container; not a big deal. Now, I just...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Danby DDR401 Dehumidifier RSS Feed Post a New Problem
Beeping full signal
Is there a way to turn the beeping full signal off. I would rather it just shut down, very annoying when people are...
Post a Solution
danby dehumidifier E3 flashing display
I took it appart and found the sensor, where can I buy a new one or do you have any suggestions
Post a Solution
danby dehumidifier
went i turn on the machine it goes on for 2 or 3 seconds then jumps the braker
Post a Solution
'E3' is flashing on the display
There is 'E3' flashing on the display, the fan running only and no water coming in the tank; would you please let me...
Post a Solution
Danby DDR255 Dehumidifier
pucket switch is ok but wont turn on only the fan setting will work
Post a Solution
Post a Solution
Compresser runs, no water is removed
If I turn on the dehumidifier, the compressor starts running as normal, but no water is collected in the bin. I've run...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Sq. Ft. Coverage2000 Sq. Ft.
Pints per 24 Hrs40 Pints
Bucket Capacity12 Pints
Humidity ControlHumidistat
Technical Features
Quiet OperationWith Quiet Operation
Automatic Overflow ProtectionWith Automatic Overflow Protection
Drain HoseConnectable
Dimensions
Depth14.75 in.
Height27.75 in.
Width15 in.
Weight55 lb.
Warranty
Warranty1 Year
Danby Contact Information
Main support number1-800-26-DANBY
Email supportconsumers_usa@danby.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
