20 Most Recent
Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2 CHANNEL Car Audio Amplifier Questions & Answers
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Hooking it up
Not to worry, if you visit any electrical shops you will get the right size of the EYE TAGS that will fit your amplifier connection. You can carry you amplifier along to check this out. I am sure with patience identify and connect, check the connection leads carefully and your amp will power on. OK. Good day
Mounting amp to car
make sure you mount where you can get a good ground and where it can get enough air to keep cool. underneath the car seat is where a lot of installer put the amp, and if you are going power up a lot i would think about mounting a fan to blow air on it to keep it cool. i have fans connected to my laptop power supply transformer to keep the unit cool, here other ideas you will never be told, putting little holes around power supple, fan area, any where there a lot of heat is generated the air flow helps it stay cooler while powering up the amp.
good luck and be safe rod
