20 Most Recent Bugaboo Cameleon Frog Canvas Breezy Sun Canopy White Pink Red Black Sand Questions & Answers
Loose main pivot
Hi - We would recommend you contact Bugaboo for assistance. support bugaboo United states English
1/3/2015 11:26:21 AM • Bugaboo Cameleon... • Answered on Jan 03, 2015
Handlebars not latching
v:* {behavior:url(#default#VML);} o:* {behavior:url(#default#VML);} w:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} A lot of locking problems are just poor lubrication so before you start opening parts, get a can of Silicon Spray (Bugaboo use to include a can in their maintenance kit). Any hardware or Gas Station will sell it. Don\'t use Oil based lubricants like WD40 the main reason being they stain fabrics and attract dirt. Remove the seat unit and lay the stroller on its side faulty hub down. Now look on the inside edge of your handle where it joins the plastic hub, you\'ll see two slots in the plastic hub and a wire rod in the lower slot. Spray into this slot so lubricant flows down inside the hub. Now wipe off excess with a paper towel and work the release button a few times. If you are lucky your handle now works. Bugaboo handle issues can be caused by faults in either the release buttons or the hubs and the first job is to try and diagnose the part causing the fault. I\'ll describe how the locks work then go into more detail on each part. Two aluminum lock pins sit in channels of the inner hub and extend into pockets in the outer hub, locking the hub. These lock pins are retracted by the rotation of a plastic disk connected to the ends of the lock pins by two small plastic pins on the disk. A wire rod clips into the disk and runs up the handle to the release buttons. There are two versions of the release button. The older pull up knob type (Gen 1) and the newer rocker button type (Gen 2). Both versions pull up the wire rod, the Gen 1 rod clips into a black plastic block in the handle and the release knob screws in to it. The (Gen 2) has a rocker button that moves the rod up via a white plastic block clamped to the wire rod by two small Alan/hex screws. A compression spring sits above the plastic blocks of both versions held by the caps where the upper handle comes out. The spring keeps the downward locked position until upward moment from the release buttons unlocks it. Check that the cap is fixed down. If not that is most likely your problem. If you are missing a spring your local hardware shop can find something similar. It does not have to be exact but if using a different spring change both sides so both sides have the same \'feel\'. clip_image002.jpg . Release Button Repair The old pull up release button (Gen 1) rarely fails which is fortunate, as you have to drill out the rivets in the handle holding the hubs to pull it out. The (Gen2) is easier to get to which is fortunate as it does fail and can be your problem the most common fault being the two screws holding the rod coming loose. clip_image004.jpg clip_image006.jpg From the brake (left) side remove the two Phillips screws and the inner half of the assembly will come off rocker button attached. The brake lever, inner brake release button and spring will be loose so carefully place aside in a small container till ready to reassemble. The right side has no screws it just clips together. Use a small flat blade screwdriver to pop the joints on the front and back edges, the inner plate with rocker button attached will come free. There is a metal plate sitting over the hole the rod is in. Take time to remember how it fits in the hole and the angle you take it out. This will make putting it back much easier. The wire rod runs though a white plastic block clamped by an inner metal block with two inset hex screws. The hex key is 0.05 inches or a 99-20 if you have Xcelite hex drivers. Adjust the rod by pulling a few mm though the block and relocking. Don\'t take up any more then required to unlock the hub other wise the locking rods won\'t fully engage in the hubs when locked. Hub Repair 1/. Remove the capped star lock washer. Use a small painters knife to protect the plastic first hammer the knife in between the dome and the plastic, then hammer a large flat blade screwdriver in between the dome and the knife. Work from one side than the other to "walk" the dome up and off the shaft. There may be a second plain star washer under the Dome you can use a small screwdriver to "walk" that up and off too. Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hubs and disks are mirrors of each other and not interchangeable the locking rods are interchangeable. Bugaboo designate the side with the brake lever as left, the Bugaboo parts will have an "L" after their serial numbers. 2/. Check the hubs for wear. If too badly worn or damaged you will have too much movement in the locked position. You can fix this by cutting a 20 mm section of a 3 to 4 mm house nail drilling a hole the same as the nail in the damage hub wall next to the pin then epoxy it in. clip_image014.jpg clip_image016.jpg clip_image018.jpg 3/. There are three parts in the hub, a plastic disk and two aluminum-locking rods. The disk has two plastic pins that move the locking rods in and out of cannels in the inner hub. Why Bugaboo use plastic for this vital component is a mystery to me? If you need to repair the disk you can try drilling out the pin stumps and using a cut down 4 mm cap bolt. clip_image020.jpg clip_image022.jpg Or (my preferred choice) have a new disk fabricated that will last a lifetime. The locking rods if broken can only be replaced, either by ones salvaged from another frame or new laser cut or 3D printed copies. I prefer the copies as they have been cut / printed from stainless steel. I sell both metal $30.00 and plastic $10.00 disks, and the stainless steel locking rods $16.00 each direct from <shapeways.com/shops/bugabooparts> Shipping is only $6.00 to USA $9.50 EU and $20.00 for the rest of us 8-( If you are in Australia or New Zealand contact me directly [email protected] for better shipping direct from New Zealand 3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position try pulling the handle up to it\'s full extension, if that does not work loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws (note I\'m now finding some frames now have pop rivets, drill them out and replace with self tappers) and wiggle things into alignment. (I use a small amount of the silicon grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern. Repeat operation on the other side if necessary. Once repaired, I can\'t empha enough, the need to keep Bugaboo hubs well lubricated. They have to endure incredible forces from the handle. To give you some idea, a crow bar of the same length can pull six-inch nails out of hard wood! If you have further questions or require other parts you can contact me
9/20/2014 9:41:17 PM • Bugaboo Cameleon... • Answered on Sep 20, 2014
Pram repair
We recommend you contact Bugaboo direct for assistance. support bugaboo United Kingdom English
9/14/2014 9:08:01 PM • Bugaboo Cameleon... • Answered on Sep 14, 2014
Bugaboo back wheel
Hi Please contact Bugaboo for assistance support bugaboo United states English
9/14/2014 10:55:04 AM • Bugaboo Cameleon... • Answered on Sep 14, 2014
Bugaboo does not recline
Hi We would advise you to contact Bugaboo for assistance support bugaboo United states English
9/14/2014 10:17:39 AM • Bugaboo Cameleon... • Answered on Sep 14, 2014
Bugaboo cameleon recline
Hi, We would advise you to contact Bugaboo for assistance support bugaboo United states English
9/14/2014 10:17:14 AM • Bugaboo Cameleon... • Answered on Sep 14, 2014
Bugaboo Cameleon Frog Canvas Breezy Sun Canopy White Pink Red Black Sand Logo
1 questions posted
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Cameleon Bugaboo
  • Cameleon Bugaboo
Most Popular Question
bassinet assembly bugaboo cameleon
  • Baby Gear
