20 Most Recent Sony VO-9800 VCR Questions & Answers
Remove the bottom cover and flip the circuit board out of the way.
Check to see that the capstan drive belt is not loose or broken.
Also, open the top cover and check the drive belt for the cassette transport.
Sony VO-9800 VCR | Answered on Sep 29, 2017
Nope it's in the user menu and you have to have video going into the deck to read it on the monitor video out put. Head hours are the time the tape actually is in contact with the drum and the most accutate easy indication of drum ware. 3/4 Umatics don't eat heads as a rule. I think I only replaced 1 out of hundred for thousands and thousands decks. Brokers love head or durm hours tipically it's T2 on the menu.
Sony VO-9800 VCR | Answered on May 08, 2015
VO-9850 error 90
Sony VO-9800 VCR | Answered on Dec 15, 2013
No, this U-Matic VO-9800p ist a PAL Model, it only Records in SP and High Band Mode. If a SP Tape is inserted, it Records SPMode, otherwise High Band. Low Band Mode is only for Playback !
(Low Band Playback is of very poor Quality, do not use this for Digital DVD Captureing )
Sony VO-9800 VCR | Answered on Aug 23, 2010
There is a converter called the YCP-688 that did exactly this-- converted the Y/C 688 signal coming out of the Umatic deck to a Y/C 358 signal that any modern device with a s-video port (VCR, edit deck, capture card) could accept.
The company went out of business in 2007 , don't know if they are still for sale-- here's a link to it-
http://www.smithav.com/ycplus/docs/688.pdf
Sony VO-9800 VCR | Answered on May 16, 2010
go look at fixya manuals on manual dir
Sony VO-9800 VCR | Answered on Mar 02, 2010
it is available for download from sevicemanuals.net for about
$30.00
Sony VO-9800 VCR | Answered on Sep 02, 2009
most likely problem is a broken threading belt. take the bottom panel off the deck; you should be able to see the belt. you may need to take three more screws out to let the large board hinge out from the bottom in order to view the belt.
Sony VO-9800 VCR | Answered on Aug 05, 2009
You can try a cord from a computer printer. You may be able find one of these at a local thrift store usually has loads of those or one that you can use with your machine.........Thank You for using FixYa.com
Sony VO-9800 VCR | Answered on Jun 30, 2009
sony vo9800 http://www.tvprogear.com/catalog/productinfo.aspx?id=304&AspxAutoDetectCookieSupport=1
sony bvu 800 http://umatic.palsite.com/bvu800spec.shtml
Sony VO-9800 VCR | Answered on May 07, 2009
this sounds like the belts on the take-up pinch wheel if it's streached then it's going to be fast if you can find all belts that take tape to drum and read heads then check each one if streached replace if all fails when replaced belts then it needs repair. hope this works
Sony VO-9800 VCR | Answered on Jan 14, 2009
you have to use the "dial menu operation"! where the buttons "menu" "data" and "set"
Sony VO-9800 VCR | Answered on Oct 13, 2007
Connection might be broken
Sony Televison &... | Answered Yesterday
Sorry. We are unable to see your message. Could you please type it in the latin alphabet?
Sony VO-9800 VCR Logo
31 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony vo 9800p u matis sp compatibility
  • Televison & Video
