20 Most Recent
Fujitsu dl3700 pro matrix printer Questions & Answers
Fujitsu fi-7160 / fi-7180
The F4:C2 error on your scanners indicates that there is a problem with the background changeover unit, specifically with the black and white (BW) servo motor. It sounds like you have already done some troubleshooting and found that the motor is operating correctly and the changeover flaps and lamps are also working fine. However, the problem seems to be with the scanner's control system not recognizing the correct position of the flaps and continuing to try to move them, causing the gears to slip and the error to occur.
Here are a few additional suggestions for troubleshooting the issue:
- Check the sensor that detects the position of the changeover flaps and ensure that it is clean and properly connected.
- Check the control board or main board of the scanner for any signs of damage or wear and check all the connectors.
- Try to re-flash or update the firmware of the scanner.
- If the problem persists, try replacing the control board or the main board of the scanner.
I have a fujitsu fi-6130 scanner and when i try to download the drivers it say incompatible and my computer deletes the downloads i have a window 10 pro
Unfortunately, the problem is the Windows 10 version. The first few versions of Windows 10 worked with TWAIN scanners. I've forgotten the exact release (possibly 20H2) and later versions of Windows 10 require the WIA (windows image acquisition) scanner drivers. The switch was around the same time as Windows' release that required manufacturers digitally sign the drivers.
The work-around to continue using some TWAIN scanners is the VueScan software from
https://www.hamrick.com/ . This software translates between TWAIN and WIA so that Windows 10 accepts the use of the scanner. Download the software and check if it works with your scanner before you decide to purchase it. The fi-6130 is listed as a supported scanner; I still recommend testing the software. The software puts a watermark on scanned documents when you use the free version. The automatic document feeder will not work properly in the free or basic version. You need the standard or professional license to use the ADF properly.
I hope this helps.
(I have an older TWAIN flatbed scanner (Microtek scanMaker S100) and use with VueScan. The hardest part is remembering to open the software. I used Windows Fax and Scan with the scanner since Windows 7 when I got the device.)
Fujitsu fi-5900c-u1 05 error,
FUJITSU FI-5900C OPERATOR'S MANUAL Pdf Download ' ...
https://www.manualslib.com/manual/662390/Fujitsu-Fi-5900c.html
Page 1 P3PC-1432-08ENZ0 fi-5900C Image Scanner Operator's Guide... Page 3: Introduction INTRODUCTION Thank you for purchasing the fi-5900C Image Scanner. The fi-5900C is an image scanner designed to scan various documents in large quantities. The fi-5900C has the following features. This manual describes the scanning method using ScandAll 21.
My ScanSnap S1500 does not
To scan a document into the computer you have to start the scan from the manager on the computer ...and there for you need it installed if you do not have it ..The button on the scanner will not send the scanned result to the computer ...but if you choose the job from the desktop command ..
so ..open the printer/scanner utility ..choose scan ..and the mode document or picture..and proceed..
it will ask you where to save it ..or auto place it in the my documents /my scans
If you do not have the complete software ..here is the download support on the site of the manufacturer and you can get the full version from there ..
http://www.fujitsu.com/global/support/computing/peripheral/scanners/ssfaq/setup-pg.htmlget the download form ..fill it up ..and get the snap scan manager ..and use it ...if you have it ..just open it and make the scanning from there ..
Scanner not found scandall pro
Unplug the USB cable and delete the software.
Reinstall the software but don't plug the scanner in until the software tells you to.
