FixYa.com
ASUS Pundit AB-P2600  Barebone
All Products > ASUS > Barebone Systems
Problems with ASUS Pundit AB-P2600 Barebone?
Search inside ASUS Pundit AB-P2600 Barebone Knowledgebase
Troubleshooting and Support
Solved Problems for ASUS Pundit AB-P2600  Barebone RSS Feed Post a New Problem
Asus Pundit AB-P2600 (pundit P4 533 HT/MD)
I would like an instruction manual for the above mentioned product. It would be most excellent if I can download one...
2 Solutions
I have re started my
I have re started my computer, I am using the installation disk, when I plug in the usb cable it stalls at 7/8 done. ...
1 Solution
where is the ink cartridge
where is the ink cartridge located on the hp psc 2110v all-in-one printer, scanner, copier
1 Solution
HP Printer Conflict
I have an HP PSC 1310 printer. It works fine at first after rebooting, then just won't print anymore. I have to reboot...
1 Solution
Canon Pixma photo printer had
Canon Pixma photo printer had a bad printer jam. All ink was wasted, shredding the paper inside. We have all the paper...
1 Solution
Initially I installed HP Photosmart
Initially I installed HP Photosmart C4280 without any problem om my PC (Vista). Then I had to format the PC, and it...
1 Solution
Problems with Canon MF8180c
I have a Canon MF8180c It will not print over the network or via USB. It will not send faxes or copy and if it scans it...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeStationary
Form FactorMini Tower
ChipsetSiS 651
Highest Supported CPU Speed2800 MHz
Technical Features
Expansion Slots2 x PCI
Input / Output Ports4 x USB 2.0, 2 x IEEE 1394a (FireWire), 1 x RS-232 Serial Port, PS/2 Keyboard, PS/2 Mouse, 1 x Parallel Port
Extension Drive Bays1 x 3.5" Bay, 1 x 5.25" Bay
Power Supply200W
Motherboard
Bus Speed533 MHz
Supported ProcessorsPentium 4
Memory
RAM TechnologyDDR SDRAM
Max. Supported RAM2 GB
Audio / Video
AudioLine In, Microphone, Headphones, SPDIF In, Line Out, SPDIF Out
Graphics ProcessorSIS 315
Hard Drive
IDE Type1 x IDE
Operating System
Compatible Operating SystemsMicrosoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional
Dimensions
Depth14.06 in.
Width3.58 in.
Warranty
Warranty1 Year
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
