20 Most Recent
Sylvania 6427FF TV Questions & Answers
Channels
If you have a menu button on the front of the Tv, you could search for an autoprogram or channel search menu and select that. Otherwise a cheap universal remote might be needed. You also want to make sure it is selected to receive antenna and not cable channels.
How do you put the tv in game mode without a
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
MisaLIGNMENT
Are the Double images different colours. If so, may need the convergance adjusted.
It wont turn on!
I know you would expect a Tv to last longer than that, but for that brand, I believe it quit right on schedule. It could be anything from a blown fuse associated with a failed part from a power surge, or just defective capacitors in the power supply.
Sylvania Model 6427FF; Serial V31567989
You probably have a couple of resistors out as well as a shorted D396 Zener Diode that is supposed to keep the voltage regulated at 8.2 Volts DC. With it being a Sylvania brand, it is probably not worth repairing.
