Dell W2606C 26 in. HDTV-Ready LCD Television
Problems with Dell W2606C 26 in. HDTV-Ready LCD Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Dell W2606C 26 in. HDTV-Ready LCD...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Dell W2606C 26 in. HDTV-Ready LCD Television RSS Feed
View More Results for Dell W2606C 26 in. HDTV-Ready LCD Television
Questions and Unsolved Support Problems
Unsolved Problems for Dell W2606C 26 in. HDTV-Ready LCD Television RSS Feed
Answer
I have a w2607c. The power light flashes 5 times when plugged in. What does this mean
Answer
Two vertical blurred lines outlining the 4:3 aspect ratio screen can be seen when the tv is in... (More)
Answer
hello! I have a similar problem. my tv turns on once in a wile, and then woes of again. i let it... (More)
Answer
i just brought this Dell TV. the people said that sometimes you turn the power on the TV and maybe... (More)
Find a Manual
Dell W2606C 26 in. HDTV-Ready LCD Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Plasma TV no pictures
If you hear a relay clicking all the time when you turn your plasma TV on is often just a few capacitor and resistor to replace. Cheap and every body... written by wings_it
tv in
always check the cables that are feeding the tv written by crcelect
Lamp vs Ballast
This is to help explain the short lives of Lamps. WARRANTY: If a lamp fails within the first year replace Lamp and Ballast. If Lamp explodes do not... written by BIG IRISH
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Dell W2606C 26 in. HDTV-Ready LCD Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the Dell W2606C 26 in. HDTV-Ready LCD Television
0
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Dell W2606C 26 in. HDTV-Ready LCD Television
Write a review:
Rate this product:
Would you recommend the W2606C 26 in. HDTV-Ready LCD Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Dell W2606C 26 in. HDTV-Ready LCD Television
Key Features
Screen Size
26 inch
Contrast Ratio
800:1
Digital TV Standard
HDTV-Ready - Requires separate receiver to view HDTV signals. · HDTV-Ready
Flat Panel Type
LCD
Display Resolution
1366 x 768 pixels
Display Capabilities
Built-in Tuner
NTSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Image Quality
Brightness
500 cd/m??
Viewing Angle
170
Adjustable Color Temperature
With Adjustable Color Temperature
Remote Control
Remote Control
Standard
Illuminated Remote
Non-Illuminated
Audio Features
Audio Type
Virtual Surround
MTS Stereo
SAP / MTS Stereo
Audio Leveler
With Audio Leveler
Technical Features
Picture in Picture
Without PIP
Parental Control
Proprietary
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
With Headphone Jack
Rear Input Connectors
Composite x 1 · RF x 1 · Audio (Mini Jack) x 1 · S-Video x 1 · Component x 2 · DVI x 1 · Audio (RCA) x 5 · 1 x D-Sub (RGB PC)
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output Connectors
Screen Text
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 15 Watt
Dimensions
Depth
4.25 in.
Height
15.91 in.
Weight
31.97 lb.
Warranty
Overall Warranty
1 Year
Dell Contact Information
Main support number888-560-8324, 800-624-9896
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
