Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo
Problems with Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Westinghouse LTV-40w1 HDC 40.02 in. HDTV...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo RSS Feed
View More Results for Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo
Questions and Unsolved Support Problems
Unsolved Problems for Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo RSS Feed
Answer
My westinghouse tv/dvd will not accept disc. It shows ''open'' when I push eject and I do not... (More)
Answer
Where can I get a base for my LTV40w!HDC which recently was lost?
Answer
my rca hdtv d52w27d power button turn on 3 times and then turn off but no picture
Answer
The DVD player in my combo will not start the DVD playing without having to put it in serveral... (More)
Answer
I have a 20" Westinghouse MOdel LTV-20v4. Have sound and very dark picture almost NO... (More)
Answer
for some reason we have no sound on cable on my tv but the sound works with the dvd player.... (More)
Find a Manual
Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo Manuals & Guides
Tips & Tricks
(Post a New Tip)
How to test an infared remote control device
How can I tell if my remote is working? You could invest in an infared detector pen or device that will detect the infared signal or you could use a... written by premtech
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Vizio Factory Menu
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV. Here's how to... written by TechNerd
My LCD TV has sound but no picture.
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input. Try unplugging... written by ginko
My TV picture has a greenish tint.
The first thing to check is the cables connected at the back of the TV. Check cable connection, and try using a different cable, video signal is... written by ginko
Help FixYa, Help you and help others. Share your User maunals and service...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Dish Network Television Remote Codes
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the... written by stoneheaded
Info on replacing polaroid caps
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After... written by prowler21
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo
Write a review:
Rate this product:
Would you recommend the LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Westinghouse LTV-40w1 HDC 40.02 in. HDTV LCD TV/DVD Combo
Key Features
Screen Size
40.02 inch
Playable Disk Types
CD-RW · CD-R · DVD Audio · VCD · DVD-RW · SVCD · DVD Video · DVD+RW · DVD+R · DVD-R
Contrast Ratio
700:1
Digital TV Standard
HDTV - HDTV receiver is integrated. · HDTV
Flat Panel Type
LCD
Display Resolution
1366 x 768 pixels
HDCP Support
With HDCP Support
Combo Features
Playable File Formats
WMA · MPEG4 · MPEG1 · MPEG2
Display Capabilities
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Image Quality
Comb Filter
3DYC / 3D Digital
Brightness
400 cd/m??
Output Color
16.7 million colors
Viewing Angle
178
Adjustable Color Temperature
With Adjustable Color Temperature
Remote Control
Remote Control
Standard
Illuminated Remote
Non-Illuminated
Audio Features
Audio Type
Stereo
MTS Stereo
SAP / MTS Stereo
Technical Features
Picture in Picture
With PIP
Parental Control
Proprietary
Sleep Timer
With Sleep Timer
Connectors
Rear Input Connectors
Audio (Mini Jack) x 1 · Component x 2 · 1 x D-Sub (RGB PC) · Audio (RCA) x 3 · HDMI x 1
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1
Front Output Connectors
Audio (RCA) x 1
Screen Text
OSD Languages
English
Closed Caption on Mute
Without Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 9 Watt
Dimensions
Depth
6.5 in.
Height
26 in.
Width
41.2 in.
Weight
57.4 lb.
Warranty
Overall Warranty
1 Year
Westinghouse Contact Information
Main support number800-245-0600
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
