20 Most Recent Gateway M675 Notebook Questions & Answers
OVERHEATING ~ me thinks ~ especially at the CPU where most heat is generated!
SEE this YOUTUBE to learn how to get the BOTTOM off... Take your Gateway to a tire shop and blow it out thoroughly!
Bring a MASK and a SOFT / OLD paint brush and round toothpick to assist.
Pay SPECIAL attention to the FAN area AND the DUST UNDER it!
SEE the PHOTO below AND NOTE the DUST UNDER the fan! Many times that fan gets IMPACTED with dust and dirt! So again ~ clean thoroughly!
Anthony
Gateway AIO ZX4250 Teardown 1 3
Gateway M675... | Answered on Dec 16, 2017
you will have to check online for your BIOS setup it is trying to boot from something that is not there have to set BIOS from UEFI to normal.
Or
Install windows using thumb drive and win32disk to install windows to thumb drive then boot from thumb drive by pressing F12 or F11 for boot order
Gateway M675... | Answered on Feb 28, 2017
Hi Ken, The link below is a youtube video showing how to connect your laptop to the WiFi, Also There's videos down the right side of the link that may help as well...........CHEERS..
How to connect your Laptop to Wifi
Gateway M675... | Answered on Apr 30, 2016
try re installing windows 7 with a operating system cd (windows 7 professional) hope this would help
Gateway M675... | Answered on Jan 29, 2016
Have you tried removing the battery and putting it back in?
Does the laptop boot when the power cord is plugged in? With and without battery?
What does the battery charge icon in the task bar (down by the clock) show?
These are the first steps I use when troubleshooting a charge problem.
If none of these yield a solution than it's time to look deeper. And it *may* be a problem with the motherboard or more specifically with the charger port or board. The next question would be, is your laptop still under warranty? Laptops are not fun to take apart.
Gateway M675... | Answered on Feb 15, 2011
Make sure the terminals are clean and connecting with the battery. Is the battery new?
Gateway M675... | Answered on Jan 30, 2011
The BIOS battery may have been drained out because the only time it charges is when the laptop is powered on. Check the BIOS battery - you might need to replace it.
Gateway M675... | Answered on Jan 23, 2011
I would suggest either taking the laptop in for service to have them remove the case an remove any dust build-up on the heat sinks.
If you're good with a screw-driver, you might try to do the cleaning yourself.
You can't really clean the air vents well without taking apart the laptop.
Gateway M675... | Answered on Dec 21, 2010
I would place bet on the LCD going/gone bad. If it works with an external monitor that is about all that is left. Google LCD replacement for screens.
Gateway M675... | Answered on Sep 03, 2010
This is usually indicative of either the fact there is no hard drive installed in the system, or the hard drive is blank and there is no operating system. The third possibility is that there is a problem between the motherboard and the hard drive, not allowing the interface between the two to work. Check the hard drive and its connections first. You can always remove the hard drive and using an adapter attach it to another computer so it will be recognized as an external drive and access the drive for viewing the files if there are any.
Gateway M675... | Answered on Aug 08, 2010
This might have something to do with the battery.
Have you tried to boot it up without the battery in it?
Regards.
Gateway M675... | Answered on Jul 14, 2010
Its possible that your slot could be dirty, you can try re seating the stick and then cleaning it with a brush. If that don't work you can just run it with one stick, last resort is to replace the motherboard.
Gateway M675... | Answered on Feb 25, 2010
From the information, that you used control/alt/delete to re-boot, I am assuming that you sensed that the computer finished the booting process. Meaning the tell tale sound (music) of windows booting was there, the hard disk whirling (blinking LED) for a certain period and stopping etc. If that is the case, (meaning you think your computer is capable of booting) probably you have a display failure. If you have a VGA cable connect that cable to the VGA connector (0n your laptop) and connect the other end to Desktop screen (monitor) or a TV screen with a VGA input. Probably you will see a display right away. If not press the Fn key and the key which changes the screen from laptop to external screen. This key will be marked either as CRT/LCD or with a picture( a square with two lines on either side of the square). If you get a display there, you may need to get a technician to change the screen.
Gateway M675... | Answered on Feb 11, 2010
Insert a Bootable CD of the operating system that is on your PC either it is XP or Vista and allow it to boot from CD then follow the instruction to repair the OS of your pc.
Gateway M675... | Answered on Jan 16, 2010
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Gateway M675... | Answered on Jan 09, 2010
Gateway M675 Notebook Logo
45 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
M Gateway
  • M Gateway
Most Popular Question
gateway m675 fan runs almost
  • Computers & Internet
