I have a flat screen Philips LCD televsion and it won't turn on. Do you have any ideas what the...
(More)
I have a flat screen Philips LCD televsion and it won't turn on. Do you have any ideas what the problem could be and how to fix it. I have changed the plug fuse.
my 37' phillips LCD telivision model# 37pf732ld has the same problem.Yesterday the menu screen came...
(More)
my 37' phillips LCD telivision model# 37pf732ld has the same problem.Yesterday the menu screen came on by itself.i turned it off and 5 min later it happened again.kept getting more frequent naw it goes back to menu immediately after upon turning on and after reset,HELP!
the exact same thing happened to my Philips 50 PF 7521 D used to use it with the pc all the time...
(More)
the exact same thing happened to my Philips 50 PF 7521 D used to use it with the pc all the time but whilst plugging the dvito hdmi lead into the tv once i got a spark and its not worked since, i have not tried making the pc detect another screen then swapping over, hopefully someone has a solution to this,
I used to connect the TV to my PC via a DVI-to-HDMI cable. Once hotplugging the TV there was a spark...
(More)
I used to connect the TV to my PC via a DVI-to-HDMI cable. Once hotplugging the TV there was a spark an since then the PC doesn't detect the TV-Set the HDMI works, but only if i open the DVI Port on the PC connecting it to another set and then to my TV. So i think there is something broken with the hot plug reset, or the EEPROM with the EDID data. I hope its just some transistor or resistor of the hot plug detection but im not sure.
While watching a DVD the Tv lcd dispaly went from a green light to a red flashing light and th tv...
(More)
While watching a DVD the Tv lcd dispaly went from a green light to a red flashing light and th tv screen went blank. I have tried to unplug to re set it but oncer it is turned on for a few minutes the same thing happens
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
