20 Most Recent Gateway MX6710 Mobile Entertainment Notebook PC, 15.4" LCD, Intel Centrino Dual-Core, 100GB HDD (803281) PC Notebook Questions & Answers
I want to have xp on my vista gateway laptop
Hello, Its really hard to downgrade from vista to XP on dell laptops. vista and XP use completely different drivers and dell has stopped writing drivers for XP. But still you can downgrade. You need to setup external SATA harddrive from where your XP CD should boot as it wont boot from your current harddrive that has vista. Even if you set these up and downgrade, Since dell has stopped writing drivers your new XP will not work with many new softwares and applications as you wont have drivers for them. I would advice you to use Vista. Good luck, Please rate the solution. ~regards, Jegan
6/3/2009 11:18:40 PM • Gateway MX6710... • Answered on Jun 03, 2009
I need to factory restore
Not enough information to answer. Need manufacturer and specific model number before we can help. Generally, though, laptops come with one of three ways to restore. 1. The manufacturer supplies a restore disk. This can be a self-booting image of the original load, or it can be an OS disk and an accompanying drivers disk that needs to be installed to restore the unit. 2. The manufacturer provides an application on the drive that the user is supposed to use at the time of purchase to create a set of recovery disks. This application is usually a 1-time-only thing and you cannot make multiple recovery sets with the app, but you can burn copies of the disk(s) you make. 3. The manufacturer places a hidden recovery partition on the hard drive that allows the user to restore the original factory image. There is usually a hotkey combination written into the BIOS that will divert the boot to the recovery sector when pressed at bootup. Some manufacturers offer both options 2 and 3. But if you got a set of recovery disks at time of purchase, chances are there is no recovery partition on the drive. Recovery partitions are nice and convenient until the problem is the hard drive itself. If you can provide a specific model number, we may be able to better determine which type of recovery option(s) are available for you PC.
12/1/2015 6:34:24 AM • Gateway MX... • Answered on Dec 01, 2015
2answers
How do i open flash drive
It should be a memory card reader. Press in gently, but quickly and plastic tray should pop out.
3/3/2014 4:00:36 AM • Gateway MX... • Answered on Mar 03, 2014
El autocad es compatible con laptop gateway
Trabaja con autocad ficheros por medio de programa para reparar archivos .dwgUtiliza http://www.autocad.repairtoolboxx.com/es
6/19/2013 10:44:39 PM • Gateway MX... • Answered on Jun 19, 2013
Why is my screen sideways
Press Alt + CTRL + Down arrow at the same time, this should adjust the screen to the proper setting. A+ certified, network+ certified, MCSE 2003, MCP, 6 years+ in various IT related posittions. Windows 8, Windows 7, Windows XP, Server 2003, Mac OS X, Fedora, Ubuntu.For remote desktop support please visit me at https://www.crossloop.com/RickPoitras
5/27/2013 1:14:02 PM • Gateway MX... • Answered on May 27, 2013
My touchpad is unresponsive
Step 1: Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
2/19/2013 10:43:53 PM • Gateway MX... • Answered on Feb 19, 2013
Itunes wont open
A corrupt iTunes library prevents the iTunes program from opening and prevents Apple device synchronization. According to Apple, the iTunes library must be rebuilt, which resets the library and removes the current content in the media manager. Back up your media prior to recreating the library, as the recreating process erases all content and your Apple device will synchronize with the blank, recreated library and erase the device's information. Insert the DVD-RW disc into the computer's DVD-RW drive, and open iTunes. Click "File," "Library" and "Backup to Disc." Select the iTunes library and playlist backup and click "Next." Eject the disc after the backup completes, and close out of iTunes. Move "iTunes Music Library.xml" from your iTunes folder to the desktop. Right-click "iTunes Library" and click "Delete." Launch iTunes and click "File," "Library" and "Import Playlist." Locate and double-click the iTunes Music Library.xml file. Insert the burned disc into the DVD-RW drive and click "Restore." or Fix iTunes if It Won't Open on Your Computer b> You've clicked and clicked and clicked some more, but iTunes just refuses to launch. A non responsive program is frustrating to any computer user, but especially if all you want to do is listen to some music or download a new album. If iTunes isn't opening, there are many possible causes for this error. None of these fixes will affect your current music collection. Though you may need to tweak or reinstall some software, your MP3s will stay right where they are. Confirm that your Apple device is connected securely to your computer. If you are not trying to access iTunes via an Apple device, or if your device is connected correctly, continue to step two. Configure your firewall to allow iTunes to connect to the Internet. Many firewalls block software programs' ability to get online as a security precaution. This is because some spyware and malware is designed to transmit personal data from your computer. Making iTunes a trusted program within your firewall software is necessary for it to function properly. Create a new iTunes library file. An unstable or corrupted library file can cause iTunes to suddenly quit or not open at all. Recreating a library file is a lengthy process that depends heavily on the operating system you are using. See the iTunes Support page under. http://support.apple.com/kb/HT1451 Reinstall iTunes on your computer. If no other troubleshooting steps are successful, then the fastest way to solve the problem is to start from scratch. Hope this helps. b>
12/26/2012 11:01:23 PM • Gateway MX... • Answered on Dec 26, 2012
I have a Gateway laptop, MX8739, that will not power on
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
11/17/2012 11:49:30 PM • Gateway MX... • Answered on Nov 17, 2012
Trying to remove or reset hdd password, cannot get to bios
Hard drive password is difficult to remove. These WEB sites maybe able to help you. HARD DRIVE PASSWORD UNLOCKING - Purchase http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free) http://www.hddunlock.com/download/ .
9/11/2012 10:43:34 AM • Gateway MX... • Answered on Sep 11, 2012
I need to fix my gateway password
Lost Windows password:
  • Log in as Administrator (Try safe mode if you don't see Administator).
  • Login as other user (if other user is availible) and manage users.
  • Reformat computer.
  • Use 3rd party software to remove password.
8/29/2012 9:52:36 PM • Gateway MX... • Answered on Aug 29, 2012
Can not get audio drivers after upgrading my gateway mx6441 to windows 7
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
if your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers
rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
which will automatically search for and find the correct driver
it might take some time being free also http://download.cnet.com/2000-20_4.html
just type in what you want or need be specific you might have to try a few times to get it right
IE: motherboard name sound drivers
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
hope it helps
7/15/2012 2:43:16 AM • Gateway MX... • Answered on Jul 15, 2012
Can i just install memory and computer configure itself
(1) re-install the memory. or (2) check that computer support 2gb memory, if yes then check the memory bus speed which must be support by computer. if bus speed mis-match then it would not be work. also check memory type. ddr or ddr2 .. and which is your computer memorty slot.
7/9/2012 7:08:41 PM • Gateway MX... • Answered on Jul 09, 2012
0answers
Where is the on button on this labtop?
The on button is located slightly to the left of the keyboard, or above the keyboard with a circle and line through it.
6/16/2012 11:32:04 AM • Gateway MX... • Answered on Jun 16, 2012
My laptop wont stay on after you press the power switch
Remove the main battery and try again, have the power supply tested, if no change, the DC jack in the laptop is a common source of trouble and in some cases may need to be replaced.
5/27/2012 5:08:31 PM • Gateway MX... • Answered on May 27, 2012
AutomaticaLLy shutdown then cannot tutned it on
usually it shuts down when cpu temperature get over heated ,,, you must take the heat sink and the fan out and clean it ,,,
3/14/2012 9:36:21 AM • Gateway MX... • Answered on Mar 14, 2012
Computers & Internet Logo
1 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
MX Gateway
  • MX Gateway
Most Popular Question
want xp vista gateway laptop
  • Computers & Internet
