20 Most Recent
Cnet CWD-854 (NWCWD854) Wireless Adapter Questions & Answers
What is remote access server?
A server that is dedicated to handling users that are not on a LAN but need remote access . The remote access server allows users to access files and print on the LAN from a remote location.
No tengo el disco de instalacion
Me dieron un router inal?mbrico -g serie CWR-854v pero no tengo el cd de instalaci?n q me podr?a ayudar mi correo electronico es torigallo_123hotmail.com si alguien tiene este mismo router si podria ayudarme con el cd de intalacion q en las pajinas no consigo para descargarlo
Cnet cgs-2400 fan replacement
it's really not worth the trouble of replacing the fan, but if you really want to fix it then you can just expose the motherboard and use a regular fan on it's highest settings (make sure nothing can mess with the router, little kids and pets might play with it).
Give password
The router password can be change if you try inputting 192.168.0.1 in the command line of the Internet Explorer.
You may need another set of numbers if the router is other than a Cisco product. It could be 192.186.1.1 or 192.168.1.0 also.
You did not specify what Router you were using?
Internet not Sharing
What type of cables are you using for the connections? are they straight or cross? It could stop working if you change a straight with a cross.
Also if it has an 'uplink' port check to ensure you connect the internet link there
