20 Most Recent
Fujitsu LifeBook N3410 Notebook Questions & Answers
Fujitsu n3410 wont charge
Unfortuneately that leaves the charging circuits on the motherboard that must be faulty, "this is so rare I have seen only one in all my years of service". But I think it is a good idea to have the charge circuits tested to be sure.
Shift key is not work on fujitsu life book
You may remove the key and remove any dust in there and place it back.
This should fix the problem
Or else i think you have to change the keyboard. But in some cases, the keyboard is embedded to the motherboard. So that might be expensive, so in that case, try to use an external keyboard.
My Fujitsu LIFEBOOK N3430 Notebook does not boot
Remove the battery for 5 minutes, press and hold the power button for 3 seconds, wait 5 more minutes, put battery back in and see if everything works now. It should. This usually works.
If it doesn't, you may have a faulty memory chip causing you the black screen.
You can try removing one at a time to see if it corrects the problem.
Lastly, the ribbon cable from screen to motherboard can become piched and non responsive.
Shift keys not working
Hi:
The most likely problem is that your keyboard is failing. They are not very expensive, approx $15-20 on ebay, and are not difficult to change.
I have a Fujitsu N-series
na i dont think there is a driver issue try with a known working card and see if it does the same thing is yes than there is issue with the reader if the other card works its issue with the card which is not working
Need help
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
How can i reset bios code ?
remove the bios password by removing the
cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the
case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Keyboard
Sounds like liquid may have been spilled on the keyboard.
Plug in an external usb keyboard and check if it works.
If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
