jvc cd/video machine model hr-xv2.cd drawer wont open when button pressed hear whirring noise.video...
(More)
jvc cd/video machine model hr-xv2.cd drawer wont open when button pressed hear whirring noise.video works perfect. ive tried turning power off and keeping buttons of open/close and stop pressed in while power switched back on with no success.
I have a vm 9510 jensen the problem is the mute function comes on if i try to put the volume up or...
(More)
I have a vm 9510 jensen the problem is the mute function comes on if i try to put the volume up or down. I decidedto us the remote but now it comes on even if i hit a pot hole. Their something wrong with the nob. How can I fix this??? Thank you.
Bravo 2065 double din 6.5 monitor cd/dvd. plays the stereo fine and all controls work fine, but...
(More)
Bravo 2065 double din 6.5 monitor cd/dvd. plays the stereo fine and all controls work fine, but switch over to cd/dvd and it plays it but no sound, you can see a pic or the movie but no sound? HELP what the flippin problem!
My VM 9510 does not read none type of CD mistake appears on the screen eject disc I like it repair...
(More)
My VM 9510 does not read none type of CD mistake appears on the screen eject disc I like it repair and obtain supplies o replacements
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
