20 Most Recent Dell Inspiron 9400 Notebook Questions & Answers
Your optical drive is not working. you need to replace it.
Dell Inspiron... | Answered on Dec 10, 2017
Defective charging cord.
Dell Inspiron... | Answered on Nov 02, 2015
Hi
Bios password differ for every model, try with the below mentioned password to unlock it.
AMI BIOS PASSWORD CONDO LKWPETER
If not you have to reinstall the OS.
Thank you
Dell Inspiron... | Answered on Feb 07, 2015
That may be a problem. Contact Dell for a one-time BIOS password.
Dell Inspiron... | Answered on May 01, 2013
If you add an extension card then the onboard card would automatically stops working and the computer will give priority to the card. However, you have to make sure that the CARD is compatible with your motherboard. There are times when extension cards have conflicts with other hardware parts.
What's the build of your computer? What the specs of the card?
Please provide me with more information when you get back to me.
David
Ur battery broken down , so can not keep electric.
Dell Inspiron... | Answered on Apr 02, 2013
Sounds like a short in the inverter. Remove the bezel around the screen the long thing on the bottom is the inverter if there is a foil heat shelid close by cut some of it away from the inverter
Dell Inspiron... | Answered on Mar 29, 2013
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Dell Inspiron... | Answered on Jan 10, 2013
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Dell Inspiron... | Answered on Oct 01, 2012
are yaar !!!! ek bar system restore ker lo...ye fir driver update kr lo..ya purana driver remove kr k naya install kr lo..sound card bhi check kr lo ek baar
Dell Inspiron... | Answered on Sep 04, 2012
try starting it in safe mode....you do that by pressing the F5 key before windows starts up.. like right after you turn it on...once your in safe mode do a real good virus scan..i have seen that happen and it was a virus
Dell Inspiron... | Answered on Aug 16, 2012
First, check that the audio is not muted, either via any hardware switch/button, or via software.
If not, I'd download and reinstall the sound card drivers for your notebook here:
http://www.dell.com/support/drivers/us/en/19/DriversHome/NeedProductSelection
you will need to select your model, or put in your service tag (on the bottom of your notebook) and then look for the driver under audio in the list.
from memory the first audio file should be the one you are after.
click on download, on the right hand side.
once downloaded, run and install software, then restart the computer.
Hope this info helps.
Dell Inspiron... | Answered on May 22, 2012
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
Dell Inspiron... | Answered on May 14, 2012
Dell Inspiron 9400 Notebook Logo
176 questions posted
Clive
Clive
Alun Cox
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
firewire
  • Computers & Internet
