You have to connect or install a transducer. I will help you
to connect it.
First, determine the best location on the transom to install the
transducer.
The transducer cable has a low profile connector that must be
routed to the point where the control head is mounted. There are several ways
to route the transducer cable to the area where the control head will be
installed. The most common procedure routes the cable through the transom into
the boat.
Unplug the other end of the transducer cable from the control
head. Make sure that the cable is long enough to accommodate the planned route
by running the cable over the transom.
Do not cut
or shorten the transducer cable, and try not to damage the cable insulation. Route
the cable as far as possible from any VHF radio antenna cables or tachometer
cables to reduce the possibility of interference. If the cable is too short,
extension cables are available to extend the transducer cable up to a total of
50' (15 m).
If you will be routing
the cable through a hole in the transom, drill a 5/8" diameter (16
mm) hole above the waterline. Route the cable through this hole, then fill the
hole with marine-grade silicone sealant and proceed to the next step immediately.
Place the escutcheon plate over the cable hole and use it as a guide to mark
the two escutcheon plate mounting holes. Remove the plate, drill two 9/64" (3.6 mm) holes, and
then fill both holes with marine-grade silicone sealant. Place the escutcheon
plate over the cable hole and attach with two #8 x 5/8" (16 mm) wood screws.
Route and secure the cable by attaching the cable clamp to the
transom; drill one 9/64" dia. (3.5 mm) x 5/8" deep (16 mm) hole, then
fill hole with marine grade silicone sealant, then attach the cable clamp using
a #8 x 5/8" (16 mm) screw.
Plug the other end of the transducer cable back into the control head
connection holder
7 questions posted
26 Questions
17 Questions
1 Questions
1 Questions
7 Questions
