20 Most Recent
Garmin StreetPilot i3 GPS Receiver Questions & Answers
Update i3 maps 2009
Hi there and welcome to fixya!
I have a Garmin as well. Updating your map is super easy. Just go to
https://my.garmin.com/maps/updates.htm and enter your serial number. They will then provide you with a link to download new maps and instruction on how to install them.
Hope this helps!
If you have any more questions do not hesitate to ask and have a happy holiday,
-TJ
4/12/2016 8:03:17 PM •
Garmin...
Answered
on Apr 12, 2016
USB port on Garmin Streetpilot I2
If the USB port is loose, that means that the port has come of the circuit board. This happened to a friend of mines, his son did not look which way to orient the usb plug and used brute force.
It will need to go back to Garmin for repair unless you are or know of an excellent solderer as the conenctions are minute.
The case needs a TORX 6 screwdriver.
10/4/2013 4:23:08 PM •
Garmin...
Answered
on Oct 04, 2013
Charging the garmin 750
Page 44 of the Garmin 750 owners manual says there are three ways to charge:
auto power cord (which you have)
usb
optional ac power cable
You might get more/better answers if you post this ??? under the 750 product heading rather than i3.
7/21/2010 12:53:07 AM •
Garmin...
Answered
on Jul 21, 2010
I need a internal part for an I3
My instinct is it would be cheapest to buy a "broken screen" model off eBay and tear the mobo out of it.
Or just buy a refurb; mine was $80 with current maps (current at that time) installed.
7/21/2010 12:40:20 AM •
Garmin...
Answered
on Jul 21, 2010
How do I reset streetpilot i3
"switch off your i3, press and hold down the arrow button, then the wheel and finally the power button. Hold all three buttons down until the i3 switches on. Select 'Yes' to erase all user data. Follow the instructions and again leave your i3 outside for up to 40 minutes."
From
a Garmin help page.
7/21/2010 12:38:13 AM •
Garmin...
Answered
on Jul 21, 2010
My Garmin was purchased in 2006 and after
That is probably the case. In most scenarios you have to purchase another lock to add or upgrade maps.
You could start playing with OpenStreetMaps.org data and see if it meets your needs.
7/21/2010 12:35:13 AM •
Garmin...
Answered
on Jul 21, 2010
Hello inserted micro sd in
First try that the Garmin recognozied the SD...
- Turn the unit off
- Plug in the USB cable to the Nuvi and your
computer. Your unit should automatically turns on.
- Click Start > Settings > Control Panel >
Administrative Tools > Computer Management > Storage > Disk
Management.
- Click a Nuvi removable disk drive (either the
internal memory or your SD card drive). Right-click your mouse, and
select Change Drive Letter and Path...
- Select Edit..., select a drive letter from the
drop-down list and click OK.
- Your Your Nuvi will now be in “my Computer” with the drive letter that you
picked.
Tell us news.
6/24/2010 9:47:01 AM •
Garmin...
Answered
on Jun 24, 2010
How do I update the maps on my garmin i3
Garmin allows you one free update for your maps as long as you do it within 60 days of your day of purchase. You have to download it with your computer and then use the USB cable that should have come with your receiver to transfer the update to your GPS. After the initial free update the charge is $100.00 per year or $200.00 for lifetime updates.
4/26/2010 12:36:13 PM •
Garmin...
Answered
on Apr 26, 2010
Can't remember pin for garmin nuvi 660 fm
Either remember the PIN
OR
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If you have a Garmin Lock on your nuvi, zumo or StreetPilot c500 series
and you have forgotten your 4 digit PIN number you can unlock the device by
returning to your Security Location. The Security Location is the location that
you set when you first enabled the Garmin Lock on your device. Returning to the
Security Location will unlock your device. (Approximately 150 feet from that
location)
If you have forgotten your PIN and Security Location please contact Product
Support for assistance. Please note Garmin will require a copy of the receipt
and there will be a charge to unlock the device as this issue is not covered by
the warranty.
1/19/2010 9:20:45 PM •
Garmin...
Answered
on Jan 19, 2010
