My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!...
(More)
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit! I've checked for cracks in the bucket but its fine and collects water too but the unit still leaks:( Everything else is fine with the unit but this. What is going on here? It worked without any leaks for a couple of years and now this! And how do I fix this problem?
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the...
(More)
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the reservoir well stays dry.
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no...
(More)
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no water is accumulating in the tank. I took the back off and no ice is accumulating
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last...
(More)
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last month it shut off and now won't power up. When plugged in, the control panel will not even light up. Seems totally dead. Do you have any adice? Is there a fuse on the unit? Please advise.
My dehumidifier was working and collecting water well, than it started sounding funny, like it's...
(More)
My dehumidifier was working and collecting water well, than it started sounding funny, like it's running but not completely running, it will run like that for several minutes and than it will make a strange sound and shut off, after which it smells a little hot. I had cleaned it a couple of months ago, but it had been running fine up until about a week ago. I don't know if the cleaning I gave it has anything to do with the problem or not, I had cleaned it according to directions I found over the internet. It is a Crossley Conservator 25 qourt and is about 3 years old.
My Fedders Model A7DH65B2A dehumidifier had frozen up for the first time in the 3-4 years I owned...
(More)
My Fedders Model A7DH65B2A dehumidifier had frozen up for the first time in the 3-4 years I owned it. I unplugged it and let it thaw out overnight. I plugged it back in, turned it back on and it ran fine for a couple hours. Then it turned itself off. I let it sit overnight again and now, when I push the ON button, it beeps and the ON light stays on for 3-4 seconds, then it goes dark again and nothing is lit up.
Service and Repair, System Maintenance, Advantage Mem... Read More
Service and Repair, System Maintenance, Advantage Member Plans, Replacement & Installation, Guarantees, Air Cleaning and Purification, Duct Sealing, Duct Cleaning, Indoor Air Quality, Heating, Air Conditioning and Indoor Air Quality Products, and Commercial Services for your business.
