20 Most Recent Panasonic MC-V5745 Bagged Upright Vacuum Questions & Answers
0answers
Morphy richads cyclonic
Flip the vacuum over. Remove the cover plate. Pull the brush straight out with both hands and put new belt on. Put cover plate back on. You are ready to go.
Jim
6/14/2009 12:47:47 PM • Panasonic... • Answered on Jun 14, 2009
I CAN'T SEEM TO INSTALL A NEW UB8 BELT
  1. Remove the lower plate
  2. Carefully lift up on the agitator assembly until it clears both sides of the nozzle housing.
  3. Remove the belt from the motor shaft by sliding it off between the end of the shaft and the nozzle housing.
3.4.2 Installation
  1. Place the belt around the motor shaft.
  2. Start the new agitator assembly back into the nozzle housing by placing the side opposite the belt partially into the slot. This will hold the agitator in place and leave both hands free to place enough tension on the belt to allow that side of the agitator to return to the nozzle housing slot.
  3. Place the belt around the agitator pulley on the agitator assembly.
    NOTE: There is a place for the belt to fit on one end of the agitator assembly only. This is the agitator pulley.
  4. Use both hands to pull the belt tight, and slide the agitator assembly firmly into the slots on each end of the nozzle housing.
  5. Rotate the agitator assembly by hand to insure nothing rubs and to check for correct assembly.
  6. Replace the lower plate
9/2/2008 3:52:32 PM • Panasonic... • Answered on Sep 02, 2008
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
3/30/2008 11:38:10 AM • Panasonic... • Answered on Mar 30, 2008
How do I replace small belt on Panasonic MC-UG304?
Do you mean the beater bar belt or the motor shaft belt? If so, you need to set the vacuum in a horizontal configuration and turn the vacuum upside down. Next remove the five screws from the base plate and lift the base plate off. To replace the motor shaft belt, remove it from the outer pulley and the motor shaft. Put the new belt on the motor shaft and the outer pulley. To replace the beater bar belt, release the motor shaft belt to allow access the beater bar. Lift up the beater bar assembly to remove the beater bar belt. Replace the beater bar belt. Replace the beater bar assembly. Replace the motor shaft belt. Turn the beater bar assembly by hand to check that the unit is seated correctly. Put the base plate back on the vacuum. Align the tabs on the base plate with the slots on the vacuum and replace the five screws. The manual for the Panasonic MC-UG304 is available here: https://www.manualslib.com/manual/940210/Panasonic-Mc-Ug302.html . See page 5 for images of the steps. I hope this helps. Cindy Wells
7/11/2019 3:09:01 PM • Panasonic... • Answered on Jul 11, 2019
Model MC-UG302 upright cleaner.
I have a similar vacuum. You literally will have to flex/pry carefully to separate the plastic shroud (Horizontal part from the upright portion. Then you can remove the panel covering the motor, trace the cord to replace. Have done that several times. When you do, you might want to purchase the long industrial cord for future convenience.
2/1/2019 4:48:31 PM • Panasonic... • Answered on Feb 01, 2019
I have a Panasonic Platinum Performance Plus-on short pile carpet-too much suction,can hardly move it. Longer pile-hardly picks up anything. I've checked everything.Any ideas what this could be?
You should reset your machine when on short carpet It sounds like it's too low to the carpet making the suction too great. On long carpet you still have to raise it enough to get the right suction.' You have to get the right air flow to do a good job.
12/15/2018 9:23:01 PM • Panasonic... • Answered on Dec 15, 2018
Panasonic upright vacuum wheel replacement
Usually,you can just remove the bottom cover of the vacuum and replacing the wheel is fairly self-explanatory. Just remove the broken one and position the new and close the bottom cover. Hope that helps
6/24/2018 3:16:22 PM • Panasonic... • Answered on Jun 24, 2018
Panasonic mc ul-915 does the hand held hose still pull vac. when not in use?
I'm not sure I understand what you are asking. The hose is not designed to pull the vac but if you pull and stretch the hose out and do something to restrict the airflow into the wand or hose it can pull the vacuum towards you or tip it over. It will only do this when the hose is stretched out because the suction is trying to pull the hose back to the vacuum but if it can't it will pull the vacuum towards the hose.
4/23/2018 12:26:34 AM • Panasonic... • Answered on Apr 23, 2018
Panasonic Dirt Sensor vacuum repair
Dirt Sensors are sensitive. It doesn't take much to set them off. Try pulling back on the handle to raise the brushroll a few inches off the floor so you know it's not detecting particles of soil. If the light doesn't turn green it may have dirt on the sensors and need to be cleaned.
11/26/2017 2:04:40 AM • Panasonic... • Answered on Nov 26, 2017
My Panasonic vacuum sounds weird I cover a little blower vent and it goes back to normal sounding Just changed bag filter doesn't look real dirty, never changed
if the noise goes down when you cover the hole, the problem is that the vacuum hose or that side of the machine is blocked that is less load for the motor and so it goes faster blocking the hole prevents air out and so the motor slows down the same effect as if you put you hand over the hose , the motor speeds up
1/6/2017 2:37:30 AM • Panasonic... • Answered on Jan 06, 2017
Replacing belt on Panasonic EC-T4650.
You must remove the roller assembly to install the belt.
10/17/2016 7:59:37 PM • Panasonic... • Answered on Oct 17, 2016
How do I open a Panasonic Power Nozzle to replace the belt? The Vacuum Model # is MC-V9635
The top part of the nozzle pops off just put small screw driver on side and lift up under the top lid is 2 screws then pop off by putting screw driver on sides to lift the housing off base plate here is roller Sears Kenmore Brush Roller 8192670 8175102 And 742454 and roller Sears Kenmore And Power Mate Canister Power Nozzle Belt Part 20 5285
7/3/2016 11:22:08 AM • Panasonic... • Answered on Jul 03, 2016
Panasonic MC-V5745 Bagged Upright Vacuum Logo
Popular Tags
6 questions posted
Top Panasonic Vacuums Experts
john h
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Vacuums
  • Panasonic Vacuums
Most Popular Question
part numbers washers end caps vacuum
  • Vacuums
