20 Most Recent Acer TravelMate 2413LCi Notebook Questions & Answers
I will assume that by reboot you understand reinstall the operation system and I will give you the options for it ..
First and the most simple way is to use the recovery partition some laptops came with from factory , and reinstall eh system completely .to do so you need to have one ..and to engage it press F11 on start or press f12 to get the boot menu and choose the partition for recovery from the menu and press enter .This will start it and you probably have some options for repair or reinstall from scratch ..If you do not know the exact key ..take a close look when it starts cause it is indicated on screen ..
Another way it is to use a recovery disk ..and the procedure is to start the computer with the disk inside and if it asks you to press any key to boot from the disk do it and will start the recovery ..If it does not asks it means the boot order have to be changed from bios .To do so ..press F2 on start and go to bios ..and in there select advanced settings ..and under the boot sector ..select the CD /DVD to be the first boot device ..After selecting it press F10 to save the settings and restart .It will work .
3rd posibility in case there is no recovery disk or partition available is to use a boot-able disk with the operation system on it , and same way ...Insert the disk ..be sure you select the boot device in bios ..and press any key when it asks to start installing the OS ..Or ..if you do not want to mess with bios settings ..just insert the disk ..and restart ..and press f12 right the way ..and in the boot menu ..select single action boot from disk drive ..and enter to engage ..it will ask to press key to confirm and start loading files..
When you get to the agreement you confirm it ..and after that select the C drive for to install into it ..and go on ..(I suggest to format the drive in quick mode (ntfs )
Acer TravelMate... | Answered on Dec 23, 2011
Does it ask for a password Immediately when you turn it on? (CMOS password) or does windows boot up and then ask for both a username and password?
If the first, and you don't know what your password is, you can try clearing the CMOS by pulling the battery from the motherboard.
If it's a windows password, you or someone else created a password for it. Try just clicking OK, or enter Administrator as the username and leave password blank. Otherwise you may have to reset using ultimate boot CD.
Acer TravelMate... | Answered on Apr 16, 2011
According to the specification sheet, it has integrated wireless networking (802.11g). If you have any other questions about how to activate it or connect to the internet using it then just post a comment here and I'll get straight back to you.
Regards,
Matt
Acer TravelMate... | Answered on Mar 04, 2011
If the required driver is not shown in device manager, download an updated driver.
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Acer TravelMate... | Answered on Mar 03, 2011
Hi Stuart1948,
Click below and download LAN drivers depending on the Operating system of you Notebook: http://support.acer.com/us/en/product/default.aspx?modelId=179
Rgds
Acer TravelMate... | Answered on Feb 15, 2011
When you turn on computer look for Acer logo on boot up. Press F8 or F10 or F2 while the logo comes up several times (if you miss turn it off and try again)and then you can access your bios. Use arrow keys and enter to clear the password. Follow the bottom of the screen for directions and if you need more help let me know and thanks for using FixYa.
Acer TravelMate... | Answered on Feb 01, 2011
You should have a light on the notebook indicating that the power supply is plugged in (this should come on with or without the laptop being turned on). My acer has a green light for power, and the battery indicator shows amber for charging and green for full. If you are not seeing the power or charging indicators, you either have a damaged power jack, or a damaged power supply. Power supplies can be purchased usually for fairly cheap online, but if your power jack is damaged, the laptop will have to be serviced by a service center, or by someone who is skilled with a soldering iron and the disassembly and reassembly of laptops.
Acer TravelMate... | Answered on Feb 28, 2010
easy when the activation appears
click activate by telephone. it then will generate a bunch of numbers ID colum a b c d e etc.
then you will have to call there the number is on top of the a b c d colum and its a n automatic machine..
AND tell the automatic machine that number.
Acer TravelMate... | Answered on Feb 19, 2010
http://www.tinyempire.com/notes/ntldrismissing.htm. read here lots of info for the NTLDR
Acer TravelMate... | Answered on Oct 05, 2009
hi well if u have a problem with ur aspire 5100 driver check it by going to 1) right click on my computer 2) choose properties 3) click on device manager 4) check if there is any question mark on any device
then download any driver u need from this official site from acer here
ftp://ftp.work.acer-euro.com/notebook/aspire_5100/driver/
but as an advice download all these drivers and install it again over ur drivers then check the problem again
alos if it's not working u need to install the Klite software from here
http://www.free-codecs.com/download_soft.php?d=5286&s=775
and when u install it choose "Lots of stuff" not "default"
hope this work
Acer TravelMate... | Answered on Jul 25, 2009
Acer TravelMate 2413LCi Notebook Logo
41 questions posted
Ekse
Alun Cox
View Most Popular
TravelMate Acer
  • TravelMate Acer
Most Popular Question
reboot aspireone
  • Computers & Internet
