Fedders D Chassis A6D24E7A Air Conditioner
Problems with Fedders D Chassis A6D24E7A Air Conditioner?
Troubleshooting and Support
Solved Problems for Fedders D Chassis A6D24E7A Air Conditioner RSS Feed Post a New Problem
Fedders Window unit
Fedders A3D18E78_A , cools fine for bout 5 to 10 min, comp suts off hard, when try to start busses, wait 20 min, starts...
1 Solution
comp shuts off
hi there my window unit blows cold air for 5 to 10 mins then the comp shuts off and it bl;ows hot air if i turn off then...
1 Solution
FEDDERS D CHASSIS A6D24E7A
MY FEDDERS WINDOW UNIT BLOWS COLD FOR 5 MINS THEN THE COMP SHUTS OFF AND FAN BLOWS HOT AIR IF I TURN OFF THE AC UNIT...
1 Solution
Unit Does not blow cold air
The unit does not blow cold air on any setting. the filter is clean.
1 Solution
Compressor runs all the time
Hello, Suddenly (while running) the compressor on this unit runs all the time-does not cycle in and out-even when the...
1 Solution
Air Conditioner unit won't switch on ...
The air conditioner is a split system unit. The inside unit switches on for about 15 seconds but there is no air and...
1 Solution
timing belt
jaguar x type year 2002 milage 77,000 I don't have a manual and would like to change the t/belt I don't know if its...
1 Solution
Unsolved Support Problems
Unsolved Problems for Fedders D Chassis A6D24E7A Air Conditioner RSS Feed Post a New Problem
compressor shut off and e-3 code appears...
after running 5 to 10 minutes the compressor will shut off & 'E-3' will show in the display. sometimes the fan will...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Other Features
Moisture Removal (Pt/h)8.5
FilterReusable
ENERGY STARWithout ENERGY STAR®
Key Features
TypeThru-Wall/Window
Remote ControlWith Remote Control
Cooling Capacity24000 BTU/hr
Energy Efficiency Rating8.5 EER
Fan Speeds (Cooling)3
Dimensions
Depth25.38 in.
Height17.25 in.
Width26.5 in.
Fedders Contact Information
Main support number217-347-6459
Email supportcrsfreeform@fedders.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
bobotfel Wiz
6 solutions
Ask Me
Eblackadd Guru
3 solutions
Ask Me
Saigua Wiz
2 solutions
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
