20 Most Recent
Sony VAIO VGN-S580P Notebook Questions & Answers
How to get to hard
Unfortunately Sony doesn't make it easy, its requires quite a bite of work to pull it apart to swap it out. Here is a guide on how to take it apart: http://www.insidemylaptop.com/how-take-apart-sony-vaio-vgn-sz-series-laptop/
5/17/2011 7:11:15 AM •
Sony VAIO...
Answered
on May 17, 2011
How to fix a key on a keypad
This is a common problem and easily fixed, so don't worry. The key on your keypad has retainers under the keypad. You need a set of tweezers to squeeze the retainers and then place the key over and it should lock in place.
If your key is still intact with your keyboard, but its just not working. You could get a Phillips flathead screwdriver and pry the key and see if there is anything wrong under. Maybe it might be sticky. You could try cleaning it with a Q-tip. Put the key back on just like the steps above.
Hope this helps!
3/1/2011 4:28:58 AM •
Sony VAIO...
Answered
on Mar 01, 2011
Upgrade Sony VGN-S580 to 2GB memory
flip the notebook upside down and disconnect the power adoptor and remove the battery from the notebook and you will have a flap showing a rectangle shape open that flap and hold the memory in45deg in the slot and press the memory in and it will get lock in the slot
3/12/2009 5:19:01 PM •
Sony VAIO...
Answered
on Mar 12, 2009
Hi i need my vaio
Go to the following link provide your product information and download all you need to.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
2/2/2009 10:52:06 AM •
Sony VAIO...
Answered
on Feb 02, 2009
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM •
Sony VAIO...
Answered
on Jan 22, 2018
My laptop has limited internet access. I've called
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
12/28/2017 11:26:53 PM •
Sony VAIO...
Answered
on Dec 28, 2017
