Troubleshooting & Support
Hot Topics:
- compressor
- water dispenser...
- temperature
- water leak
- control lock
- water dispenser
- ge monogram...
- replace defrost...
- COMPRESSOR HOT
- hot
- fan
- model
- high ...
- defrost cycle
- reset
- condenser...
- fuse
- temp
- noise
- freezer fan
- cold
- freezer noise
- dispenser...
- door
- thermistor
- repair
- damper
- clean condenser
- inverter
- View All »
Problems & Solutions
leaking water
remove all the food from your refrigerator, check if the hose who brought water in pan located in the back is not block inside.unplug your...
the water dispenser is very slow on our ge
The water line is clogged or water dispenser valve is blocked.Click this link below for...
Ge moogram Model# PSB42YSXSS The first time I went
Hey Rkraft, i may have answered that question in the comment ya posted on the other Monogram But now as i think about it how is the frost...
Ge monogram side by side freezer is at -5 fridge
Hello,John Tripp surely gave you good solid info,one thing ya should be looking for since the frost pattern is good and the fan is...
model zfsb27d ss .. has
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
When I depress my water dispenser, no water comes
check all tubing that leads to water despinser may be cracked or have came lose in chilling coil inside of fidg.
The refrigerator is working fine.
Take a look at your compressor relay. When they go bad they make the same clicking noise. service manual
The freezer temperature varies over periods of
I just recently had that problem with a monogram, it turned out to be the temp control unit it's inside the refrigerator. It's...
Hi we have a 6
Hi, Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that...
the temperature is rising
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost...
I've set the freezer as low as it will go but...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around...
GE Monogram refrigerator feeezing even when
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through...
ge zisw48dyb hot to touch on middle bar front...
Pull the refrig out and remove the lower panel . Check that the fan motor is working and no object is blocking the blade to keep it from...
I think I need to replace the thermistor...
You can get exploded view drawings of your refrigerator from any of the appliance part dealer web sites or the GE web site. Simply enter...
GE Monogram side by side compressor runs loud -
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the...
Unsolved Problems
how to put back the plastic cover on the lights at...
the plastic cover fell off fromthe ceiling of the fridge. When we try to put it back there is a piece of a moveable...
no refridgerator lights
everything else, including freezer lights works fine. I have checked refridgerator bulbs and the are not blown
GE monogram refrigerator is leaking warm water
My fridge is leaking warm water from underneath at the back, please advise.
not working
not cooling
Why is unit not cooling
not cool
ziss42dxass
LED lights in the refergerator section went out for the third time in three years. What...
ice cube button
The solid ice cube button gives crushed ice. The crushed ice button gives crushed ice also. The water button gives...
need instruction to instal a swicht light
Freezer light will not turn on when opening the door
GE Monogram side by side model z1s420nmc is making...
The refrigerator seems to be working fine, but the rattling noise is pretty annoying. It happens every 10 to 20 minutes...
Upload a manual for GE Monogram Side by Side Refrigerator
Specifications
TopKey Features
Full Product Name:GE Monogram Side by Side Refrigerator
Type:Side by Side
Number of Motors:1 Motor
Total Volume:26.1 cu. ft.
Total Volume:30.7 cu. ft.
Fresh Food Volume:16.3 cu. ft.
Fresh Food Volume:17.8 cu. ft.
Freezer Volume:12.9 cu. ft.
Freezer Volume:9.8 cu. ft.
Ice Maker:With Ice Maker
Installation:Built-in
Installation:Free-Standing
Total Number of Shelves:4
Fresh Food Compartment
Fresh Food Shelves / Bins:Vegetable Bin x 1
Fresh Food Shelves / Bins:Snack Drawer
Fresh Food Shelves / Bins:Egg Storage
Fresh Food Shelves / Bins:Dairy Center
Fresh Food Shelves / Bins:Spill Proof Shelves
Fresh Food Shelves / Bins:Vegetable Bin (Controlled Humidity) x 1
Fresh Food Shelves / Bins:Wine Rack
Shelf Material:Glass
Door Opens:Opens to Left and Right
Light:Yes
Freezer Compartment
Shelve / Bins:Shelves x 4
Ice Maker
Dispenser:Water
Dispenser:With Water Filter
Dispenser:Ice
Convenience
Exterior Color:Black
Exterior Color:White
Energy
Amperage Rating:20 Amp.
Annual Energy Consumption:678 kWHrs
Annual Energy Consumption:622 kWHrs
Energy Efficiency:Energy Star Compliant
Dimensions
Overall Depth:23.88 in.
Overall Height:84 in.
Overall Width:48 in.
Overall Width:42 in.
Warranty
Warranty:2 Years Parts
Warranty:2 Years Parts and Labor
Warranty:12 Years Parts (Sealed System)
Warranty:5 Years Parts and Labor (Sealed System)
What's your problem?
Fix-O-Meter
23,793
23,793 people have viewed this product
- 275 people asked about this product.
- 73 people found solutions for this product.
- 16 people have added this product.
General Safety...
Pins on the...
How to fix your...
