Fedders SFPEB08F2A Air Conditioner
Problems with Fedders SFPEB08F2A Air Conditioner?
Troubleshooting and Support
Solved Problems for Fedders SFPEB08F2A Air Conditioner RSS Feed Post a New Problem
Parts for Fedders Portable Air conditioner...
Someone gave me just the unit itself. I need the vent hose and the window adapter. I found them online, but before I...
1 Solution
hunter thermostat
i need to know how to put it on cool from heat without using the reset button
1 Solution
Honeywell T8000C Thermostat Problem
Came back from a vacation and found the downstair thermostat's display blank. I tried all - reset breaker, reseat the...
1 Solution
heater lights for about 5 sec and then...
when you turn on the heat to my ruud package unit the ignitor lights the flame and then it goes out after about two...
1 Solution
Leak repair Samsung window air conditioner
Model AW08ECB7 Samsung air conditioner. In attempting to drill a hole in the frame to allow the water to drain, I...
1 Solution
Amana 80SSE Furnace
We have an Amana 80SSE Furnace. The furnace came on by itself when the thermostat was turned off. It was blowing cool...
1 Solution
Sanyo 12KS71 Split Air Conditioner
Installed in 5/07, ran fine for 3 months, then it would not start - no lights, nothing. Reset breaker and it ran fine,...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Other Features
Moisture Removal (Pt/h)1.75
FilterReusable
Air Flow170 cfm
Key Features
TypeStand Alone/Portable
DehumidifierWith Dehumidifier Functionality
Cooling Capacity7500 BTU/hr
Energy Efficiency Rating7.5 EER
Fan Speeds (Cooling)2
Electrical Requirements
Voltage115
Cooling Ampacity7.5
Cooling Watts800
Dimensions
Depth17 in.
Height33 in.
Width17 in.
Fedders Contact Information
Main support number217-347-6459
Email supportcrsfreeform@fedders.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
Joe_Rex Guru
1 solutions
Ask Me
RepairUSA Wiz
3 solutions
Ask Me
bobotfel Wiz
6 solutions
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
