20 Most Recent Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player Questions & Answers
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Sony Xplod Car... | Answered on Mar 13, 2016
Do you have an antenna plugged into the back of the radio?
If you do, you may have a bad antenna or a bad tuner.
Sony Xplod Car... | Answered on Apr 21, 2011
The error 4 in most Sony stereos is an error that comes up when the laser pickup doesn't read the disc correctly. This happens most of the time because of a dirty lens in the laser pickup. If anyone smokes in the vehicle the smoke may be on the lens causing the error code. Try a wet type CD cleaning disc to see if it helps.
Sony Xplod Car... | Answered on Dec 03, 2010
no not at all a deck can never power a subwoofer you need an amp the only speakers a deck will power is your fronts and rears aka mids and highs. you will need an amp to run a subwoofer. I hope I answered your question, if so please vote and leave high marks. Thank you very much
Sony Xplod Car... | Answered on Aug 03, 2010
yellow is constant and the red is the acc, black of corse is brown
the matching colored wires grey purple.....
all corraspond to each other
goto sony.com and find the support page find any cd players manual and it should have the exact wiring guide for the sony harness , all of them are the same, they only change with brand i.e pioneer, aiwa, jvc.....
Sony Xplod Car... | Answered on Jul 16, 2010
all your wires are color coated for a reason you want to make sure before trying to figure out anything that you do indeed have your new wiring harness and then the harness that connects to your reciever those two harnesses will match color for color every wire will tie to each other your ground your power your ignition your audio and so forth if you have any question on what color of wires go were look at your manual to your reciever it will tell you. you have red, yellow and black those will be your ground your constant 12+ and you ignition or acc wire. the rest is just for sound to your speakers. you will have a blue wire that says remote on it do not mess with that wire unless you are hooking an amp up you may have a an orange wire coming out of the unit wich you need not be concerned with it is the wire that would be used if you were tying the dimmer switch to you dash to the unit but do not mess with that wire either you should be in the clear but if anything else comes up that your not familar with give me a call i can walk you though it my names josh 832 248 4144
Sony Xplod Car... | Answered on Nov 02, 2009
ok check for good earth and also check you 12v constant 12 acc... aslong as you have all three it will work...
Sony Xplod Car... | Answered on Sep 22, 2009
I have a Sony CDX GT 530U. I had a problem with no display and I thought no power period. I did not try to install a CD, so maybe I did have power to the CD motor but no display. This was frustrating because I could get the old factory Nissan radio to power up and work so I thought I had a dead Sony unit. After a lot of monkeying around, I discovered I had blown a fuse while installing the unit (you should disconnect the negative terminal of the battery when installing the radio... which I thought I skip, that was a no no.). I had checked the auto fuses, those cheap little plastic fuses behind a panel below the stearing column inside most cars, at least all the fuses I thought went to the car stereo. Turns out I missed one that was labeled "Batt" or something like that, which was the constant power wire to the car stereo. There was another fuse for the Accessory power to the car stereo (the main juice went the key is tuned to ACC or Start position). Turns out the Sony unit display runs off the constant power, or at least the unit on/off button runs off the constant power wire, so even though the ACC power wire was live, the Constant power wire had a blown fuse and the unit would not turn on. Check all your fuses inside the car, I bet that's your problem. Constant power on my Nissan Sentra was a 7.5A fuse, while the ACC power ran off a 15A fuse, but your vehicle may vary. Good luck.
Sony Xplod Car... | Answered on Jul 18, 2009
Check the wires of the stereo ,check the ground and disconect him and put it to a chassis part, some cars got a black wire for dimming the lights maybe that´s your case.Good luck
Sony Xplod Car... | Answered on Jul 03, 2009
He probably needed to disconnect the battery to perform a repair or diagnostic. Then, as it is not factory, did not hook the power wire back up.
Sony Xplod Car... | Answered on Jan 14, 2009
you may have fried it but check the fuses and find the exposed hot wire look for one thats black and melted and seel it up good
Sony Xplod Car... | Answered on Jan 10, 2009
If I were in your shoes I would hardwire it, Run the red wire directly to fuse box or battery, run yellow wire to switched circuit in fuse panel, and isolate the black ground wire somewhere inside the dash, I'm in America and have not wrenched on any FIAT's, but in my expirence some manufactures doe things proprietary, give this a shot.
Sony Xplod Car... | Answered on Sep 27, 2007
If you stop by any car stereo shop, you should be able to purchase a wiring harness that will plug into your car's plug. You can then wire it up to the wires coming from your sony by matching up the standard wire colors.
Sony Xplod Car... | Answered on Sep 21, 2007
Sony Xplod Car Audio CDX-F7810 - CD/MP3 Player Logo
26 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
sony explod cd player
  • Car Audio & Video
