This really sounds like you are getting a bad signal for one reason or another. Sometimes it will sound like the signal is scrambled, cut in and out or seem like it is delayed or slow of sorts.
This can be cause from a bad placement in the antenna.
The antenna itself can be failing.
The wire for the antenna is often ran through a door or window and from being kinked and pinched can negate the coax.
Always make sure the antenna is pointing to the south
Always make sure the antenna has a clear and open area to receive the be reception.
There are some things to try.
The first thing is you can try to "refresh" your connection.
If you bought it within a year, it should be under OEM warranty. If it has been longer than a year, but shorter than two years, and you bought it with Visa, MC, or American Express, you probably qualify for extended warranty protection from your credit card company.
If they are paired together by color, you can turn the raido on and hook one speaker up and then use the fade and balance controls on the radio to figure out which wires go to which speakers
Unfortunately, no one knows or is telling. Companies rarely state power in RMS because Peak Power is a much more impressive. 1000 watt amp, 200 watts RMS x 2 channels at 8 ohms. Look for a sticker on the unit.
https://www.google.com/search?q=Xplore+Amp+5553
'year make model' of the vehicle is needed in questions like this please?
Modern vehicle radios are controlled by the Body control Module (BCM) and are used for broadcasting warning beeps and indicator clickers. The beeps an be as innocuous as "do you know your radio is still on"? It can also be caused by your cellphone pinging local transmitters and receiving a confirmation back, or checking in for emails.
JustAnswerhttps://www.justanswer.com > Mercedes Repair
Aug 26, 2010 - What causes a beeping noise to come over the radio speakers? How can it be made to stop? - Answered by a verified Mercedes Mechanic.
1 answer · Top answer: Chat Conversation Started Pete : Hello,I will be glad to try and assist you with this,Welcome ...
Missing: periodic ' Show results with: periodic
iFixithttps://www.ifixit.com > Answers > View > Why+is+m...
Apr 6, 2019 - My speaker has suddenly began making a single sound every few seconds which sounds like a single busy signal on a phone. I have read the manual, ...
11 answers · Top answer: It's low on battery. Plug it in!
Answershttps://www.answers.com > Auto > Auto Parts
Oct 26, 2022 - Press the AS button and hold depressed while turning the radio on. (after 3 secs you should hear a beep. Release the AS button. The display ...
