20 Most Recent Jensen MSR4050G CD Player Questions & Answers
Audio from a DVD player is at line level and the Ipod is at ear phone level. You popped the input circuitry of the 4050. It probably can be repaired.
Jensen MSR4050G... | Answered on Jul 28, 2017
if you have power it wouldn't be a fuse. if there is no audio, it could be a bad speaker (or more) causing the problem. a bad or shorted speaker can cause the radio's amp to overload and shut down. use an ohm meter to check the speakers and the wiring. above 4 ohms is a good number. below2 could cause problems.
Jensen MSR4050G... | Answered on May 11, 2011
Error 01 is normally on most machines to say it cannot read the discs. Could be dirty laser or a defective one. Must open to make better diagnosis.
Jensen MSR4050G... | Answered on May 12, 2009
Unplug the unit for a few hours. If the display still does not work, you have a bad display driver or the backlight is bad. Good Luck
Jensen MSR4050G... | Answered on Apr 26, 2009
Do you still need the face plate for a 5110? I have one with case. if so e-mail me @ [email protected]
Jensen MSR4050G... | Answered on Jan 01, 2009
I had the same problem and there are a couple of reason why you may not be able to get into Sirius Mode.
  1. You have the wrong type of antenna (it must be a Sirius approved antenna)
  2. You may not have installed the tuner (most Sirius ready units need require that you have a tuner hooked up to your unit to get satellite reception. The tuners are specific to your unit, so make sure you but the correct one. This is quite sneaky on Sirius’ part…but good luck).
Jensen MSR4050G... | Answered on Aug 04, 2008
Sirius Mode Selection
While in Sirius satellite radio mode, press S-MOD (22a) (also the SHIFT/SCAN button) to select
from four available modes: Normal, Category, Direct Tune and Set Skip Channel. When the
Category or Set Skip Channel modes are selected, the corresponding icon appears in the display.
When the DIrect Tune mode is activated, the alphanumeric display appears.
Click on this link to get the user manual:
http://www.asaelectronics.com/techpdf/MSR4050G%20Owners%20Manual%207-11-05.pdf
good luck...
Jensen MSR4050G... | Answered on May 19, 2008
YOU HAVE TO GO INTO THE MENU SETTING
Jensen Car Audio... | Answered on Sep 12, 2019
It depends upon whether the sub is powered or passive and impedances match.
Jensen Car Audio... | Answered on Sep 07, 2019
Ribbon from player to screen not properly connected or broken due to unfolding and folding.
Jensen Car Audio... | Answered on Jul 17, 2019
Car Audio & Video Logo
Popular Tags
19 questions posted
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
aux in not working jensen msr4050g
  • Car Audio & Video
