FixYa.com
Fedders V Chassis A6V10S2A Air Conditioner
All Products > Fedders > Air Conditioners
Problems with Fedders V Chassis A6V10S2A Air Conditioner?
Search inside Fedders V Chassis A6V10S2A Air... Knowledgebase
Troubleshooting and Support
Solved Problems for Fedders V Chassis A6V10S2A Air Conditioner RSS Feed Post a New Problem
Fan will not start
This is a brand new unit. The compressor will start but the blower will not start?
1 Solution
Heater!!!
Unit acts like its heating but there is no hot air. Fan turns on, heat symbol is showing on the remote, but no heat
1 Solution
thru wall GE A/C
a/c is leaking a lot of water into room. Unit recently installed and has been running good for several weeks.
1 Solution
air conditioner
When in cooling mode, cooling unit shuts off after 10 min. with fan still running and flashes E3 on display.
1 Solution
Heat pump trips circuit breaker
The heat pump in my air conditioning system trips the circuit breaker... what do I do?
1 Solution
Light gray smoke
There is a light-gray, odorless smoke coming from my ac unit. It still blows cool air, but it starts blowing smoke...
2 Solutions
Will constantly running a central AC...
Will constantly running a central AC system on a very cold setting, such as 65-F, damage the system?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Other Features
Moisture Removal (Pt/h)3.1
Key Features
TypeThru-Wall/Window
Remote ControlWith Remote Control
Cooling Capacity10000 BTU/hr
Energy Efficiency Rating9.5 EER
Fan Speeds (Cooling)3
Dimensions
Depth24.25 in.
Height20.5 in.
Width14.5 in.
Fedders Contact Information
Main support number217-347-6459
Email supportcrsfreeform@fedders.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
