FixYa.com
Jensen XA2150 Car Audio Amplifier
All Products > Jensen > Car Amplifiers
Problems with Jensen XA2150 Car Audio Amplifier?
Troubleshooting and Support
Solved Problems for Jensen XA2150 Car Audio Amplifier RSS Feed Post a New Problem
wiring
i have an us audio amp. i don't know which wire should be inserted first, kindly help me which wire should be put first...
1 Solution
kenwood kac-7202 amp
i have a kenwood kac-7202 amp and don't know exactly how many watts it is.would anybody know?
1 Solution
jensen xa2150 amplifier
hi, i have a jensen xa2150 300watt amp and the wiring has been done by a professional. when the amp was connected to the...
1 Solution
power on
i have the jensen 300 watt xa2150 hooked up to my factory hu, so for the remote wire im putting it in with a fuse, but i...
1 Solution
Sony MEX-1GP getting warm
Hey, hello everybody! I have a Sony MEX-1GP car player with 4 speakers (3-way 60 W), and around 20 minutes with a MP3...
1 Solution
wiring diagram for a kole amplifier 1920
I need a visual diagram for my kole amplifier 1920 and the answer to what a "tri mode capable" is
1 Solution
MA Audio HK4002
I am getting bored with seeing this amp sit in the corner of the basement collecting dust. I had it fixed once by a...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Jensen XA2150 Car Audio Amplifier RSS Feed Post a New Problem
Sound comes on, goes away
It is definately NOT temp related. I have to get this amp fixed because I bought it 7 years ago and its molded into a...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Amplifier TypeDual Channel
BridgableBridgable
RMS Power at 4 Ohms75 W x 2
RMS Power at 2 Ohms100 W x 2
Performance
THD at Rated RMS Power.1%
Signal to Noise Ratio100 dB
Frequency Response20 Hz - 20000 Hz
Crossover / Equalizer
Bass BoostWith Bass Boost
Bass Boost Frequency45 Hz
High - Pass Frequency50 Hz - 250 Hz
Low - Pass Frequency50 Hz - 250 Hz
Other Features
3 Way ReadyYes
Input Voltage14.4 volt
Dimensions
Depth8 in.
Height2.25 in.
Width11.13 in.
Jensen Contact Information
Main support number800-645-4994
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
