20 Most Recent
Sunbeam Health at Home Warm Mist Humidifier Humidifier Questions & Answers
Hello...i have a sunbeam filter
Hi, have you given it a while? That humidifier usually takes about 10 minutes to get going. After 10 minutes or so you should be able to feel the warm mist coming out, and soon after you should feel a difference in the moisture in the air.
Need the manual for Sunbeam humidifier swm2311
El manual de instrucciones del humidificador Sunbeam SWM2311 est? disponible para su descarga desde la p?gina web Sunbeam. Para descargar el manual del usuario, vaya a www.sunbeam.com/support/manuals y seleccione la opci?n "Humidificadores". Puedes encontrar el manual de instrucciones del Sunbeam SWM2311 en la lista de descargas disponibles
1/6/2023 2:32:03 AM •
Sunbeam...
Answered
on Jan 06, 2023
Sunbeam sul2512 humidifier leaking.
The Sunbeam SUL2512 Humidifier has three parts. From the top down:
Water tank
mist collar
Base unit
If the cap of the water tank (which contains a float valve) does not seal you may get excessive flow into the base unit which provides a working reservoir.
The base unit contains all the electronics including the cool mist transducer. This is a silver disk with a black silicone seal surrounding it. This is the only other place a leak can develop.
5/2/2018 9:35:34 PM •
Sunbeam...
Answered
on May 02, 2018
How to clean the fan in sunbeam humidifier
Go to Walmart and get Canned Air used to blow out debris from keyboards etc. Place the air tube near the fan vents and blow out debris. Keep the can up-right. Should you turn it upside-down, you will FREEZE everything, so do it correctly.
2/7/2018 9:03:52 PM •
Sunbeam...
Answered
on Feb 07, 2018
