FixYa.com
Epson EMP-S3 Multimedia Projector
All Products > Epson > Multimedia Projectors
Problems with Epson EMP-S3 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Epson EMP-S3 Multimedia Projector RSS Feed Post a New Problem
projector problem
image is flickering constantly and the colour is turning pink
1 Solution
yupar
my projector is can not working, it show only blue screen eg : source :computer (Auto) no signal .(? help)
1 Solution
EPSON EMP-S4 PROJECTOR
IT WON'T SHOW MY VIDEO CLIPS ON THE BIG SCREEN
1 Solution
epson emp-s3
my projecter has just stopped working no lights no power have changed power lead. can you tell me if there is a fuse or...
1 Solution
Projector problems
Hi, I have a 3m MP7730 projector that keeps going into standby mode. I switch it on and it works fine, it warms up and...
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
LCD shutting off automatically
I use a Benq LCD projector to give powerpoint presentations. Lately the projector shuts down shortly after powering up....
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeLCD Projector
Form FactorStationary
Display TechnologyTFT Active Matrix
Image Brightness1600 ANSI lumens
Contrast Ratio500:1
Image Aspect Ratio4:3 (Standard)
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60
Image Size (Diagonal)35.43 in. - 476.38 in.
Screen Distance30 ft. - 300 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal15 - 92 kHz
Synchronization Range Vertical50 - 85 Hz
Video ModesStandard · Cinema · Game
Technical Features
Audio OutputSpeaker(s)
Operation Noise34 dB
Interfaces
InterfaceUSB
Video Input4 Pin - Mini DIN (S-Video) · 15 Pin D-Sub VGA (& component) · Composite Video
Lamp
Lamp TypeUHE
Light Source Life2000 Hours
Light Source Power135W UHE
Other Features
Special FeaturesKeystone Correction
Speakers Output1.0 W
Projection MethodRear · Front · Ceiling
Dimensions
Depth9.69 in.
Height3.39 in.
Width12.87 in.
Weight156.25 lb.
Epson Contact Information
Main support number1-800-922-8911
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
