BenQ CP120 Multimedia Projector
Problems with BenQ CP120 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ CP120 Multimedia Projector RSS Feed Post a New Problem
sharp digital multi media projector PG...
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on...
1 Solution
Sanyo Projector==No signal
Sanyo projector is not registering a signal when connected to a Dell laptop. I followed set-up procedure--first,...
1 Solution
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
user manual
hi i have this new beetel walk clip caller id cordless phone but i do not have the users manual,so i cannot load the...
1 Solution
InFoucus LP500 Projector
My InFocus LP500 projector has a pinkest image when connected to the Dell C840 laptop. I have update the display driver...
1 Solution
SMALL ICON APPEARS ON THE SCREEN (TOP...
USUNG A TOSHIBA PROJECTOR MODEL TLP X3000 AND WHEN WE USE THE REMOTE TO MAKE THE PROJECTORED IMAGE LARGER A SMALL X IN...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1500 ANSI lumens
Contrast Ratio2000:1
Image Aspect Ratio4:3 (Standard)
Analog Video FormatNTSC · PAL · SECAM
Image Size (Diagonal)27 in. - 270 in.
Screen Distance3.28 ft. - 36.09 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Vertical48 - 85 Hz
HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Video ModesStandard · Cinema · Game
Technical Features
Operation Noise37 dB
Interfaces
InterfaceUSB
Video Input4 Pin - Mini DIN (S-Video) · 15 Pin D-Sub VGA (& component) · Composite Video
Lamp
Light Source Life2000 Hours
Networking
Networking CapabilitiesWireless Networking
Other Features
Special FeaturesOn Screen Menu · Keystone Correction · Password Lock
Projection MethodRear · Front · Ceiling
Warranty
Warranty1 Year, 90 Days On Lamp
Dimensions
Depth6.77 in.
Height2.4 in.
Width8.58 in.
Weight2.9 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
Loading problems.
Top Experts
Ask Me
Marrie Wiz
15 solutions
Ask Me
Inky Guru
2 solutions
Ask Me
ohms Wiz
2 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
