Friedrich QStar SQ07J10A Air Conditioner
Problems with Friedrich QStar SQ07J10A Air Conditioner?
Troubleshooting and Support
Solved Problems for Friedrich QStar SQ07J10A Air Conditioner RSS Feed Post a New Problem
Friedrich qstar airconditioner
We have a Friedrich qstar from 1992. Its not cooling. Would it be cheaper to have it repaired or should we just get a...
1 Solution
hunter thermostat
i need to know how to put it on cool from heat without using the reset button
1 Solution
Honeywell T8000C Thermostat Problem
Came back from a vacation and found the downstair thermostat's display blank. I tried all - reset breaker, reseat the...
1 Solution
heater lights for about 5 sec and then...
when you turn on the heat to my ruud package unit the ignitor lights the flame and then it goes out after about two...
1 Solution
Leak repair Samsung window air conditioner
Model AW08ECB7 Samsung air conditioner. In attempting to drill a hole in the frame to allow the water to drain, I...
1 Solution
Amana 80SSE Furnace
We have an Amana 80SSE Furnace. The furnace came on by itself when the thermostat was turned off. It was blowing cool...
1 Solution
Sanyo 12KS71 Split Air Conditioner
Installed in 5/07, ran fine for 3 months, then it would not start - no lights, nothing. Reset breaker and it ran fine,...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Other Features
Moisture Removal (Pt/h)2.5
Key Features
Cooling Capacity7100 BTU/hr
Energy Efficiency Rating10.3 EER
Friedrich Contact Information
Main support number(210) 357-4400
Sponsored Links
Loading problems.
Top Experts
Ask Me
The dog Guru
1 solutions
Ask Me
koolbreez Wiz
16 solutions
Ask Me
bobotfel Wiz
6 solutions
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
