20 Most Recent
Gateway 560GE PC Desktop Questions & Answers
Need a fix for a
Take a can of compressed-air, and give a "blow-job" to the cooling-fan, to remove all the dust, which is acting as "insulation", causing the computer to run "hotter", and causing the motherboard to spin the fan faster, to try to make the computer run "cooler".
Or, enter BIOS SETUP, and check the fan-speed settings.
If the fan-speed is set to "100% for 100% of the time",
try a lower setting (which will be quieter).
No video output with onboard
First make sure your monitor connected properly to vga port.
Make sure num lock led status on keyboard.If it is on/off when you preess num lock key then cpu working ifne.
But
if num lock key is not on/off when you press num lock then you need to
open cpu cabinet then refix RAM memory.Pull cmos cell from motherboard
for 10 minutes.
Open processor and it's fan then clean dust from there then again fix processor and it's fan.
Make sure motherboard is not ground with cabinet.
Check motherboard outside of the cabinet.
Remove pci cards if any installerd then check.
When
you power up the computer press F1 or F2 or del key to enter in bios if
you are able to enter in bios then make sure vga is enabled in advanced
configuration.
Then save settings and exit.
Let me know if you need further assistance.
Thanks for using FixYa.
After a power outage, tried to power computer.
Sounds like it could be the power supply was damaged from the power outage. If you have another PC you could pull the ATX power supply out and install it in the gateway and see if it boots up. Power supplies are fairly inexpensive so look for an aftermarket one...buying a replacement from Gateway will cost alot more. If the power supply turns out to be good then remove one device at a time the try to boot up. Sometimes a bad cd-rom drive or harddrive can cause a problem. My best guess it is the power supply.
My cpu will not power up the blue light just
Flashing power light is a sign of a hardware failure. First unplug the pc and give it about 30 seconds then turn it back on. If it goes back to a blinking power light you have a hardware issue and will have to get that checked out.
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do.
First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button.
Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button.
Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation.
I hope this helps!
3/14/2023 5:41:18 PM •
Gateway...
Answered
on Mar 14, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
- Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
- Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
- Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
- Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
- Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM •
Gateway...
Answered
on Feb 26, 2023
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
2/21/2023 10:42:44 PM •
Gateway...
Answered
on Feb 21, 2023
