20 Most Recent
Kenmore 94052 Dryer Questions & Answers
Smartheat he4 11085871400
Consult your owners manual; there is a list of common error codes that will help you identify whether or not you require to bring in a technician or you can solve it yourself. Being a retired sales manager with Sears, if I recall correctly the 2f refers to a faulty control panel, if you can't find your manual go to this site:
http://www.searspartsdirect.com/?SID=MerchSearsxHSTopNavPartsDirect you should be able to download the manual there. Good Luck!
Kenmore model 94052 gas dryer
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis
electric no heat tip...
heatman101
Dryer drum will not turn.
Hello.
If the buzz continues to go for awhile(2-3 minutes before you stop it you will need to replace the belt on your dryer.
If the buzz quits pretty quickly after you let go of the start button and you smell something hot or electrical, you will need to replace the motor.
Please let me know if you have any other questions.
How to change time settings on a Kenmore series 600 electric dryer
Follow these simple steps:
- Turn on the dryer by pressing the "Power" or "Start" button.
- Use the "Time Dry" or "Timed Dry" button to select the desired drying time. Press it repeatedly to increase the time in one-minute increments or hold it down to scroll through the time options more quickly.
- Once you've set the desired drying time, press the "Start" button to begin the drying cycle with the new time settings.
My Kenmore just stopped while heating something... shows No power... any ideas?
Your Kenmore Dryer has a number of things that can cause this.
Most basic, the house breaker has tripped.
The timer or electronic mainboard has failed.
The element has failed
One of the 3 heat regulation devices has failed or tripped out, one resets itself, the thermal fuse has to be replaced.
'make model (what it is)' in all questions please.
